[postgis-users] CentOS : postgis compatibility with postgresql.
postgo at khiplus.fr
Tue Sep 7 08:56:28 PDT 2021
Thanks, it pass.
An other question but it is possible to choose the postgresql version to
install with postgis ?
Regards
Le 07.09.2021 16:01, Regina Obe a écrit :
> Those dependencies I believe are included in
> https://download.postgresql.org/pub/repos/yum/common/redhat/rhel-7-x86_64
> as noted in this thread
> https://lists.osgeo.org/pipermail/postgis-devel/2021-August/029136.html
> So you need to add that as well.
>> -----Original Message-----
>> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On
>> Behalf Of postgo at khiplus.fr
>> Sent: Tuesday, September 7, 2021 9:30 AM
>> To: postgis-users at lists.osgeo.org
>> Subject: [postgis-users] CentOS : postgis compatibility with
>> postgresql.
>> Hi,
>> For some tests, i am searching a way to install postgis with a
>> postgresql
> 11 on
>> an old centos (7.5).
>> Is there some list about compatibility of postgis and postgresql 11 ?
>> i
> can see
>> that :
>> https://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS
>> I found it on the 7.5 : postgresql-9.2.23/24 (no postgis available)
>> But i
> need
>> to upgrade in a 11's version.
>> Then i made a new repository with postgresql 11 :
>> https://download.postgresql.org/pub/repos/yum/11/redhat/rhel-7.5-
>> x86_64/
>> To install by example postgresql11 (11.13) isn't a problem, but when i
> want
>> to install postgis 2.5 there's dependency's problems :
>> # yum install postgis25_11.x86_64
>> Loaded plugins: fastestmirror, ovl
>> Loading mirror speeds from cached hostfile
>> * base: centos-mirror.usessionbuddy.com
>> * extras: centos-mirror.usessionbuddy.com
>> * updates: centos-mirror.usessionbuddy.com Resolving Dependencies
>> --> Running transaction check
>> ---> Package postgis25_11.x86_64 0:2.5.5-5.rhel7 will be installed
>> --> Processing Dependency: proj72 >= 7.2.1 for package:
>> postgis25_11-2.5.5-5.rhel7.x86_64
>> --> Processing Dependency: geos39 >= 3.9.1 for package:
>> --> Processing Dependency: gdal32-libs >= 3.2.3 for package:
>> --> Processing Dependency: xerces-c for package:
>> --> Processing Dependency: postgresql11-contrib for package:
>> --> Processing Dependency: postgresql11 for package:
>> libprotobuf-c.so.1(LIBPROTOBUF_C_1.0.0)(64bit) for package:
>> --> Processing Dependency: json-c for package:
>> --> Processing Dependency: hdf5 for package:
>> --> Processing Dependency: SFCGAL for package:
>> --> Processing Dependency: libtiff.so.5()(64bit) for package:
>> --> Processing Dependency: libprotobuf-c.so.1()(64bit) for package:
>> --> Processing Dependency: libproj.so.19()(64bit) for package:
>> --> Processing Dependency: libjson-c.so.2()(64bit) for package:
>> --> Processing Dependency: libgeos_c.so.1()(64bit) for package:
>> --> Processing Dependency: libgdal.so.28()(64bit) for package:
>> --> Processing Dependency: libSFCGAL.so.1()(64bit) for package:
>> ---> Package json-c.x86_64 0:0.11-4.el7_0 will be installed Package
>> ---> libtiff.x86_64 0:4.0.3-35.el7 will be installed
>> --> Processing Dependency: libjpeg.so.62(LIBJPEG_6.2)(64bit) for
>> package: libtiff-4.0.3-35.el7.x86_64
>> --> Processing Dependency: libjpeg.so.62()(64bit) for package:
>> --> Processing Dependency: libjbig.so.2.0()(64bit) for package:
>> ---> Package postgresql11.x86_64 0:11.13-1PGDG.rhel7 will be installed
>> --> Processing Dependency: postgresql11-libs(x86-64) =
>> 11.13-1PGDG.rhel7
>> for package: postgresql11-11.13-1PGDG.rhel7.x86_64
>> --> Processing Dependency: systemd-sysv for package:
>> --> Processing Dependency: libicu for package:
>> --> Processing Dependency: libpq.so.5()(64bit) for package:
>> ---> Package postgresql11-contrib.x86_64 0:11.13-1PGDG.rhel7 will be
>> installed
>> --> Processing Dependency: postgresql11-server(x86-64) =
>> 11.13-1PGDG.rhel7 for package:
>> postgresql11-contrib-11.13-1PGDG.rhel7.x86_64
>> --> Processing Dependency: libxslt.so.1(LIBXML2_1.0.22)(64bit) for
>> package: postgresql11-contrib-11.13-1PGDG.rhel7.x86_64
>> --> Processing Dependency: libxslt.so.1(LIBXML2_1.0.18)(64bit) for
>> --> Processing Dependency: libxslt.so.1(LIBXML2_1.0.11)(64bit) for
>> --> Processing Dependency: libxslt.so.1()(64bit) for package:
>> ---> Package protobuf-c.x86_64 0:1.0.2-3.el7 will be installed Package
>> ---> xerces-c.x86_64 0:3.1.1-10.el7_7 will be installed
>> ---> Package jbigkit-libs.x86_64 0:2.0-11.el7 will be installed
>> Package
>> ---> libicu.x86_64 0:50.2-4.el7_7 will be installed Package
>> ---> libjpeg-turbo.x86_64 0:1.2.90-8.el7 will be installed Package
>> ---> libxslt.x86_64 0:1.1.28-6.el7 will be installed Package
>> ---> postgis25_11.x86_64 0:2.5.5-5.rhel7 will be installed
>> ---> Package postgresql11-libs.x86_64 0:11.13-1PGDG.rhel7 will be
>> installed
>> ---> Package postgresql11-server.x86_64 0:11.13-1PGDG.rhel7 will be
>> installed
>> ---> Package systemd-sysv.x86_64 0:219-78.el7_9.3 will be installed
>> --> Processing Dependency: systemd = 219-78.el7_9.3 for package:
>> systemd-sysv-219-78.el7_9.3.x86_64
>> ---> Package systemd.x86_64 0:219-57.el7 will be updated Package
>> ---> systemd.x86_64 0:219-78.el7_9.3 will be an update
>> --> Processing Dependency: systemd-libs = 219-78.el7_9.3 for package:
>> systemd-219-78.el7_9.3.x86_64
>> --> Processing Dependency: libcryptsetup.so.12(CRYPTSETUP_2.0)(64bit)
>> for package: systemd-219-78.el7_9.3.x86_64
>> --> Processing Dependency: libcryptsetup.so.12()(64bit) for package:
>> ---> Package cryptsetup-libs.x86_64 0:1.7.4-4.el7 will be updated
>> ---> Package cryptsetup-libs.x86_64 0:2.0.3-6.el7 will be an update
>> ---> Package systemd-libs.x86_64 0:219-57.el7 will be updated Package
>> ---> systemd-libs.x86_64 0:219-78.el7_9.3 will be an update
>> --> Finished Dependency Resolution
>> Error: Package: postgis25_11-2.5.5-5.rhel7.x86_64 (postgresql)
>> Requires: hdf5
>> Requires: libproj.so.19()(64bit)
>> Requires: libSFCGAL.so.1()(64bit)
>> Requires: gdal32-libs >= 3.2.3
>> Requires: libgeos_c.so.1()(64bit)
>> Requires: SFCGAL
>> Requires: geos39 >= 3.9.1
>> Requires: proj72 >= 7.2.1
>> Requires: libgdal.so.28()(64bit)
>> You could try using --skip-broken to work around the problem
>> You could try running: rpm -Va --nofiles --nodigest
>> Do you know a solution to install postgis with postgresql 11 ?
>> Is it necessary to install with sources (./configure; make; make
>> install
>> Best regards,
>> postgis-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
