[postgis-users] CentOS : postgis compatibility with postgresql.
Regina Obe
lr at pcorp.us
Tue Sep 7 07:01:38 PDT 2021
Those dependencies I believe are included in
https://download.postgresql.org/pub/repos/yum/common/redhat/rhel-7-x86_64
as noted in this thread
https://lists.osgeo.org/pipermail/postgis-devel/2021-August/029136.html
So you need to add that as well.
> -----Original Message-----
> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On
> Behalf Of postgo at khiplus.fr
> Sent: Tuesday, September 7, 2021 9:30 AM
> To: postgis-users at lists.osgeo.org
> Subject: [postgis-users] CentOS : postgis compatibility with postgresql.
> Hi,
> For some tests, i am searching a way to install postgis with a postgresql
11 on
> an old centos (7.5).
> Is there some list about compatibility of postgis and postgresql 11 ? i
can see
> that :
> https://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS
> I found it on the 7.5 : postgresql-9.2.23/24 (no postgis available) But i
need
> to upgrade in a 11's version.
> Then i made a new repository with postgresql 11 :
> https://download.postgresql.org/pub/repos/yum/11/redhat/rhel-7.5-
> x86_64/
> To install by example postgresql11 (11.13) isn't a problem, but when i
want
> to install postgis 2.5 there's dependency's problems :
> # yum install postgis25_11.x86_64
> Loaded plugins: fastestmirror, ovl
> Loading mirror speeds from cached hostfile
> * base: centos-mirror.usessionbuddy.com
> * extras: centos-mirror.usessionbuddy.com
> * updates: centos-mirror.usessionbuddy.com Resolving Dependencies
> --> Running transaction check
> ---> Package postgis25_11.x86_64 0:2.5.5-5.rhel7 will be installed
> --> Processing Dependency: proj72 >= 7.2.1 for package:
> postgis25_11-2.5.5-5.rhel7.x86_64
> --> Processing Dependency: geos39 >= 3.9.1 for package:
> --> Processing Dependency: gdal32-libs >= 3.2.3 for package:
> --> Processing Dependency: xerces-c for package:
> --> Processing Dependency: postgresql11-contrib for package:
> --> Processing Dependency: postgresql11 for package:
> libprotobuf-c.so.1(LIBPROTOBUF_C_1.0.0)(64bit) for package:
> --> Processing Dependency: json-c for package:
> --> Processing Dependency: hdf5 for package:
> --> Processing Dependency: SFCGAL for package:
> --> Processing Dependency: libtiff.so.5()(64bit) for package:
> --> Processing Dependency: libprotobuf-c.so.1()(64bit) for package:
> --> Processing Dependency: libproj.so.19()(64bit) for package:
> --> Processing Dependency: libjson-c.so.2()(64bit) for package:
> --> Processing Dependency: libgeos_c.so.1()(64bit) for package:
> --> Processing Dependency: libgdal.so.28()(64bit) for package:
> --> Processing Dependency: libSFCGAL.so.1()(64bit) for package:
> ---> Package json-c.x86_64 0:0.11-4.el7_0 will be installed Package
> ---> libtiff.x86_64 0:4.0.3-35.el7 will be installed
> --> Processing Dependency: libjpeg.so.62(LIBJPEG_6.2)(64bit) for
> package: libtiff-4.0.3-35.el7.x86_64
> --> Processing Dependency: libjpeg.so.62()(64bit) for package:
> --> Processing Dependency: libjbig.so.2.0()(64bit) for package:
> ---> Package postgresql11.x86_64 0:11.13-1PGDG.rhel7 will be installed
> --> Processing Dependency: postgresql11-libs(x86-64) = 11.13-1PGDG.rhel7
> for package: postgresql11-11.13-1PGDG.rhel7.x86_64
> --> Processing Dependency: systemd-sysv for package:
> --> Processing Dependency: libicu for package:
> --> Processing Dependency: libpq.so.5()(64bit) for package:
> ---> Package postgresql11-contrib.x86_64 0:11.13-1PGDG.rhel7 will be
> installed
> --> Processing Dependency: postgresql11-server(x86-64) =
> 11.13-1PGDG.rhel7 for package:
> postgresql11-contrib-11.13-1PGDG.rhel7.x86_64
> --> Processing Dependency: libxslt.so.1(LIBXML2_1.0.22)(64bit) for
> package: postgresql11-contrib-11.13-1PGDG.rhel7.x86_64
> --> Processing Dependency: libxslt.so.1(LIBXML2_1.0.18)(64bit) for
> --> Processing Dependency: libxslt.so.1(LIBXML2_1.0.11)(64bit) for
> --> Processing Dependency: libxslt.so.1()(64bit) for package:
> ---> Package protobuf-c.x86_64 0:1.0.2-3.el7 will be installed Package
> ---> xerces-c.x86_64 0:3.1.1-10.el7_7 will be installed
> ---> Package jbigkit-libs.x86_64 0:2.0-11.el7 will be installed Package
> ---> libicu.x86_64 0:50.2-4.el7_7 will be installed Package
> ---> libjpeg-turbo.x86_64 0:1.2.90-8.el7 will be installed Package
> ---> libxslt.x86_64 0:1.1.28-6.el7 will be installed Package
> ---> postgis25_11.x86_64 0:2.5.5-5.rhel7 will be installed
> ---> Package postgresql11-libs.x86_64 0:11.13-1PGDG.rhel7 will be
> installed
> ---> Package postgresql11-server.x86_64 0:11.13-1PGDG.rhel7 will be
> installed
> ---> Package systemd-sysv.x86_64 0:219-78.el7_9.3 will be installed
> --> Processing Dependency: systemd = 219-78.el7_9.3 for package:
> systemd-sysv-219-78.el7_9.3.x86_64
> ---> Package systemd.x86_64 0:219-57.el7 will be updated Package
> ---> systemd.x86_64 0:219-78.el7_9.3 will be an update
> --> Processing Dependency: systemd-libs = 219-78.el7_9.3 for package:
> systemd-219-78.el7_9.3.x86_64
> --> Processing Dependency: libcryptsetup.so.12(CRYPTSETUP_2.0)(64bit)
> for package: systemd-219-78.el7_9.3.x86_64
> --> Processing Dependency: libcryptsetup.so.12()(64bit) for package:
> ---> Package cryptsetup-libs.x86_64 0:1.7.4-4.el7 will be updated
> ---> Package cryptsetup-libs.x86_64 0:2.0.3-6.el7 will be an update
> ---> Package systemd-libs.x86_64 0:219-57.el7 will be updated Package
> ---> systemd-libs.x86_64 0:219-78.el7_9.3 will be an update
> --> Finished Dependency Resolution
> Error: Package: postgis25_11-2.5.5-5.rhel7.x86_64 (postgresql)
> Requires: hdf5
> Requires: libproj.so.19()(64bit)
> Requires: libSFCGAL.so.1()(64bit)
> Requires: gdal32-libs >= 3.2.3
> Requires: libgeos_c.so.1()(64bit)
> Requires: SFCGAL
> Requires: geos39 >= 3.9.1
> Requires: proj72 >= 7.2.1
> Requires: libgdal.so.28()(64bit)
> You could try using --skip-broken to work around the problem
> You could try running: rpm -Va --nofiles --nodigest
> Do you know a solution to install postgis with postgresql 11 ?
> Is it necessary to install with sources (./configure; make; make install
> Best regards,
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
