[postgis-users] PostGIS and prepared statement, data_type problem
Marco Boeringa marco at boeringa.demon.nl
Sat Apr 9 02:47:03 PDT 2022
Hi all,
Reading this PostgreSQL page about prepared SQL statements:
https://www.postgresql.org/docs/current/sql-prepare.html
it suggests that 'data_type' is optional, and "will be inferred from the
context in which the parameter is first referenced" if unspecified.
Now I have attempted to create a prepared SQL statement for doing
INSERTs, which includes an "ST_GeometryFromText()" function call that
will get WKT inserted in the geometry field of the target table.
However, this fails with a "could not determine data type of parameter
$1" error for the geometry field.
Is there something PostGIS functions do not expose to PostgreSQL that
causes PostgreSQL to fail to "infer from context" the field type? Or is
this a general issue with PREPAREd statements if they include any
function call, whether PostGIS or core PostgreSQL, and are you always
required to specify data type in this context?
Marco
