[postgis-users] PostGIS and prepared statement, data_type problem
Marco Boeringa
marco at boeringa.demon.nl
Sat Apr 9 06:58:14 PDT 2022
I finally got this to work by switching to WKB and "ST_GeomFromWKB" and
specifying data_type for the column as 'geometry'.
Op 9-4-2022 om 11:47 schreef Marco Boeringa:
> Hi all,
> Reading this PostgreSQL page about prepared SQL statements:
> https://www.postgresql.org/docs/current/sql-prepare.html
> it suggests that 'data_type' is optional, and "will be inferred from
> the context in which the parameter is first referenced" if unspecified.
> Now I have attempted to create a prepared SQL statement for doing
> INSERTs, which includes an "ST_GeometryFromText()" function call that
> will get WKT inserted in the geometry field of the target table.
> However, this fails with a "could not determine data type of parameter
> $1" error for the geometry field.
> Is there something PostGIS functions do not expose to PostgreSQL that
> causes PostgreSQL to fail to "infer from context" the field type? Or
> is this a general issue with PREPAREd statements if they include any
> function call, whether PostGIS or core PostgreSQL, and are you always
> required to specify data type in this context?
> Marco
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
