[postgis-users] postgis introduction data bundle can not restore a backup.
Jian He
hejian.mark at gmail.com
Wed Apr 13 20:51:35 PDT 2022
Thanks. Problem solved.
On Wed, Apr 13, 2022 at 5:51 PM Imre Samu <pella.samu at gmail.com> wrote:
> > 5. Loading spatial data — Introduction to PostGIS
> > ERROR: type "public.geometry" does not exist
> as I see in the "4. Creating a Spatial Database"
> https://postgis.net/workshops/postgis-intro/creating_db.html
> there are 2 important step
> - create Username as postgres.
> - "CREATE EXTENSION postgis;"
> and the restore should work.
> if you see an error like "ERROR: duplicate key value violates unique
> constraint "nyc_census_blocks_pkey""
> you have to use "-c" option
> " -c, --clean clean (drop) database objects before
> recreating"
> add sometimes the "--verbose" option is also useful.
> regards,
> Imre
> Jian He <hejian.mark at gmail.com> ezt írta (időpont: 2022. ápr. 13., Sze,
> 11:32):
>> <http://postgis.net/workshops/postgis-intro/loading_data.html>
>> Introduction to PostGIS — Introduction to PostGIS
>> <http://postgis.net/workshops/postgis-intro/index.html> (data bundle)
>> I use the follow command to restore a database.
>> *pg_restore -h localhost -p 5432 -U jian -d postgis_in_action
>> nyc_data.backup*
>> I cannot load the backup file to database.
>> Too many errors like :
>> ERROR: relation "public.nyc_census_blocks" does not exist
>> There is only another .sql file. But the file only have one table:
>> *nyc_census_sociodata*
>> where can I get the table create script.
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220414/4445c2e1/attachment.html>
