[postgis-users] postgis introduction data bundle can not restore a backup.
Imre Samu
pella.samu at gmail.com
Wed Apr 13 05:17:25 PDT 2022
> 5. Loading spatial data — Introduction to PostGIS
> ERROR: type "public.geometry" does not exist
as I see in the "4. Creating a Spatial Database"
https://postgis.net/workshops/postgis-intro/creating_db.html
there are 2 important step
- create Username as postgres.
- "CREATE EXTENSION postgis;"
and the restore should work.
if you see an error like "ERROR: duplicate key value violates unique
constraint "nyc_census_blocks_pkey""
you have to use "-c" option
" -c, --clean clean (drop) database objects before
recreating"
add sometimes the "--verbose" option is also useful.
regards,
Imre
Jian He <hejian.mark at gmail.com> ezt írta (időpont: 2022. ápr. 13., Sze,
11:32):
> <http://postgis.net/workshops/postgis-intro/loading_data.html>
> Introduction to PostGIS — Introduction to PostGIS
> <http://postgis.net/workshops/postgis-intro/index.html> (data bundle)
> I use the follow command to restore a database.
> *pg_restore -h localhost -p 5432 -U jian -d postgis_in_action
> nyc_data.backup*
> I cannot load the backup file to database.
> Too many errors like :
> ERROR: relation "public.nyc_census_blocks" does not exist
> There is only another .sql file. But the file only have one table:
> *nyc_census_sociodata*
> where can I get the table create script.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220413/a9ccb617/attachment.html>
