[postgis-users] Errors with upgrading due to CVE CVE-2022-2625
Sandro Santilli
strk at kbt.io
Fri Aug 12 09:29:28 PDT 2022
On Thu, Aug 11, 2022 at 09:44:52PM +0200, Daniel Gustafsson wrote:
> I've now upgraded to 3.2.2 and the issue remains. When building and running
> make installcheck-upgrade against a 14.5 postgres cluster it fails with:
> NOTICE: Packaging extension postgis
> ERROR: function _postgis_deprecate(text,text,text) is not a member of extension "postgis"
> DETAIL: An extension is not allowed to replace an object that it does not own.
> CONTEXT: SQL statement "CREATE EXTENSION postgis SCHEMA public VERSION unpackaged;ALTER EXTENSION postgis UPDATE TO "3.2.2""
Daniel could you please confirm the issue is resolved as of
commit 9ceb6968ef780bc7d56e4e46ecf5747f95c2e619 in stable-3.2 branch ?
Thanks for reporting this!
--strk;
