[postgis-users] extension "postgis_raster" has no installation script nor update path for version "unpackaged"
Marcelo Marques marcelosmbr at gmail.com
Wed Aug 31 11:58:05 PDT 2022
oh my. sorry. forgot the '%'  thanks for catching that. Thanks a lot. :)
On Wed, Aug 31, 2022 at 11:25 AM Regina Obe <lr at pcorp.us> wrote:
> Marcelo,
> I think it’s your query and below behavior you describe as I understand it
> seems correct.
> And your output is correct:
> "POSTGIS=""3.2.3 3.2.3"" [EXTENSION] PGSQL=""110""
> GEOS=""3.10.3-CAPI-1.16.1"" PROJ=""7.2.1""
> GDAL=""GDAL 3.4.3, released 2022/04/22 GDAL_DATA not found""
> LIBXML=""2.9.9"" LIBJSON=""0.12"" LIBPROTOBUF=""1.2.1"" WAGYU=""0.5.0
> (Internal)"" RASTER"
> Instead of:
> SELECT * FROM pg_available_extensions WHERE name LIKE 'postgis';
> Should be:
> SELECT * FROM pg_available_extensions WHERE name LIKE 'postgis%';
> And then the postgis_raster should show along with postgis_topology and
> postgis_sfcgap and postgis_tiger_geocoder.
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> Behalf Of *Marcelo Marques
> *Sent:* Wednesday, August 31, 2022 2:03 PM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* Re: [postgis-users] extension "postgis_raster" has no
> -- Yes, I have Postgis 3.2.2 for PostgreSQL 11 installed and it already
> contain a file named "postgis--unpackaged--3.2.2.sql" under "C:\Program
> Files\PostgreSQL\11\share\extension"
> C:\Program Files\PostgreSQL\11\share\extension>dir postgis--unpackaged*.*
>  Directory of C:\Program Files\PostgreSQL\11\share\extension
> 03/11/2019  12:12 PM         1,475,393 postgis--unpackaged--2.5.2.sql
> 07/30/2022  12:49 AM         1,068,869 postgis--unpackaged--3.2.2.sql
> 08/30/2022  04:14 PM                21 postgis--unpackaged.sql
> -- I compared the file C:\Program
> Files\PostgreSQL\11\share\extension\postgis--unpackaged--3.2.2.sql on my
> server
> -- with the one from
> https://winnie.postgis.net/download/windows/pg11/buildbot/extras/postgis--unpackaged--3.2.2.sql
> -- and they are identical.
> -- and still fails to upgrade.
> -- SELECT postgis_extensions_upgrade();
> NOTICE:  Extension postgis_sfcgal is not available or not packagable for
> some reason
> NOTICE:  Packaging extension postgis_raster
> ERROR:  extension "postgis_raster" has no installation script nor update
> CONTEXT:  SQL statement "CREATE EXTENSION postgis_raster SCHEMA public
> VERSION unpackaged;ALTER EXTENSION postgis_raster UPDATE TO "3.2.2""
> PL/pgSQL function postgis_extensions_upgrade() line 71 at EXECUTE
> SQL state: 22023
> -- I followed you suggestion and installed Postgis 3.2.3 for PostgreSQL 11
> -- I checked and PostGIS 3.2.3 has the empty file "C:\Program
> Files\PostgreSQL\11\share\extension\postgis--unpackaged.sql"
> -- This file just has text "-- Nothing to do here"
> C:\Program Files\PostgreSQL\11\share\extension>dir postgis--unpa*.*
> 08/19/2022  04:24 PM         1,465,258 postgis--unpackaged--3.2.3.sql
> -- I was able to upgrade the postgis extension
> -- and upgrade the raster extension and then
> -- remove the raster extension and
> -- if I want I can reinstall postgis_raster extension
> -- SELECT postgis_full_version();
> GDAL=""GDAL 2.2.4, released 2018/03/19 GDAL_DATA not found""
> LIBPROTOBUF=""1.2.1"" WAGYU=""0.5.0 (Internal)"" (core procs from ""3.2.2
> 3.2.2"" need upgrade)   <== !!! 3.2.2 NEED UPGRADE !!!
> RASTER (raster lib from ""2.5.2 r17328"" need upgrade) [UNPACKAGED!]
> (raster procs from ""2.5.2 r17328"" need upgrade)"
> -- ALTER EXTENSION postgis UPDATE;
> Query returned successfully in 599 msec.
> NOTICE:  version "3.2.3" of extension "postgis" is already installed
> ALTER EXTENSION
> Query returned successfully in 160 msec.
> "Upgrade completed, run SELECT postgis_full_version(); for details"
> NOTICE:  Updating extension postgis from 3.2.2 to 3.2.3
> some reason
> WARNING:  'postgis.gdal_datapath' is already set and cannot be changed
> until you reconnect
> WARNING:  'postgis.gdal_enabled_drivers' is already set and cannot be
> changed until you reconnect
> WARNING:  'postgis.enable_outdb_rasters' is already set and cannot be
> NOTICE:  Extension postgis_topology is not available or not packagable for
> some reason
> NOTICE:  Extension postgis_tiger_geocoder is not available or not
> packagable for some reason
> Successfully run. Total query runtime: 1 secs 884 msec.
> 1 rows affected.
> -- SELECT * FROM pg_available_extensions WHERE name LIKE 'postgis';
> "postgis" "3.2.3" "3.2.3" "PostGIS geometry and geography spatial types
> and functions"
> -- CREATE EXTENSION postgis_raster;
> ERROR:  extension "postgis_raster" already exists
> SQL state: 42710
> -- NOTE: if postgis_raster already exists then pg_available_extensions
> should have showed that, seems another bug to fix !!!
> -- DROP EXTENSION postgis_raster;
> DROP EXTENSION
> Query returned successfully in 125 msec.
> (Internal)"""
> --NOTE: RASTER EXTENSION REMOVED !!!
> -- Try to install postgis_raster extension
> CREATE EXTENSION
> Query returned successfully in 252 msec.
> and functions"
> --NOTE: pg_available_extensions still does not show postgis_raster but in
> pgAdmin when expand the "Extensions" I can see "postgis" and
> "postgis_raster".
> DROP EXTENSION
> I appreciated your assistance.
> Thanks,
> Marcelo
> On Tue, Aug 30, 2022 at 8:42 PM Regina Obe <lr at pcorp.us> wrote:
> I guess my attachment was too big.
> Here is a link to it if you need it,
> but if you are running a patched PostgreSQL 11, you’ll really need to be
> using the PostGIS 3.2.3 install which you can get from application
> stackbuilder or https://download.osgeo.org/postgis/windows/pg11/
> Hope that helps,
> Regina
> *From:* Regina Obe [mailto:lr at pcorp.us]
> *Sent:* Tuesday, August 30, 2022 8:00 PM
> *To:* 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>
> *Subject:* RE: [postgis-users] extension "postgis_raster" has no
> Attached is the one for 3.2.2
> But that is in my artifacts so should have already been installed by your
> setup.  Do you have the attached file in your share/extension folder?
> *From:* Regina Obe [mailto:lr at pcorp.us <lr at pcorp.us>]
> *Sent:* Tuesday, August 30, 2022 7:56 PM
> Oh you are running 3.2.2 and not 3.2.3.  I know 3.2.3 has this file
> postgis_raster--unpackaged--3.2.3.sql
> which is what you are missing.
> Can you install 3.2.3?  Then once you install the binaries, run again and
> it should work.
> <postgis-users-bounces at lists.osgeo.org>] *On Behalf Of *Marcelo Marques
> *Sent:* Tuesday, August 30, 2022 7:39 PM
> Hello Regina,
> I tried but the upgrade still failed, see below.
> --create an empty file named "postgis--unpackaged.sql" in your
> share/extension folder of your PostgreSQL install.
> --This file just has text
> --C:\Program Files\PostgreSQL\11\share\extension folder
> --And then try your upgrade again.
> --SELECT postgis_extensions_upgrade();
> some reason
> SQL state: 22023
> --SELECT * FROM pg_available_extensions WHERE name LIKE 'postgis';
> "postgis" "3.2.2" "3.2.2" "PostGIS geometry and geography spatial types
> and functions"
> --only the postgis extension is installed!!!
> --CREATE EXTENSION postgis_raster;
> ERROR: PostGIS Raster is already installed in schema 'public' CONTEXT:
> PL/pgSQL function inline_code_block line 10 at RAISE SQL state: P0001
> --SELECT postgis_full_version();
> "POSTGIS=""3.2.2 3.2.2"" [EXTENSION] PGSQL=""110""
> (Internal)""
> Thanks for the assistance.
> Marcelo
> On Tue, Aug 30, 2022 at 3:56 PM Regina Obe <lr at pcorp.us> wrote:
> Marcelo,
> Apologies, this file was left out in my packaging.  I’ll create an updated
> package later this week to fix this issue and will also have a 3.3.0 which
> doesn’t have this issue.
> I’ve updated ticket to reflect.
> Copy  the attached file (which is essentially an empty file)  into your
> Sorry for the omission,
> Regina
> *Sent:* Tuesday, August 30, 2022 6:08 PM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* [postgis-users] extension "postgis_raster" has no installation
> Hello,
> I am trying to get a workaround for the problem below.
> see more details in this link
> https://trac.osgeo.org/postgis/ticket/5222#ticket
> Have you encountered this issue before? If yes, do you know how to fix it ?
> Thanks,
> | *Marcelo Marques *| Esri PS Products | Principal Product Engineer |
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220831/22e982e6/attachment.htm>
