[postgis-users] extension "postgis_raster" has no installation script nor update path for version "unpackaged"
Marcelo Marques marcelosmbr at gmail.com
Wed Aug 31 14:18:12 PDT 2022
Hi Regina,
I have one more question.
Platform:
Windows Server 2019 Standard
PostgreSQL 11.17 x64
PostGIS 3.2.3
Problem:
-- I installed Postgis 3.2.3 for PostgreSQL 11 and I was able to upgrade
the postgis extension to 3.2.3
-- the raster extension is still 2.5.2 and just for testing I dropped the
raster type
-- now I cannot upgrade postgis_raster
-- I can restore a backup but I wonder if there is a way to fix this and be
able to do the raster extension upgrade
-- database has no raster data, hence the goal is to upgrade the
postgis_raster extension and then drop the postgis_raster extension
-- see details below.
-- The postgis extension was updated fine to PostGIS 3.2.3
-- SELECT postgis_full_version();
"POSTGIS=""3.2.3 3.2.3"" [EXTENSION] PGSQL=""110""
GEOS=""3.10.3-CAPI-1.16.1"" PROJ=""7.2.1""
GDAL=""GDAL 2.2.4, released 2018/03/19 GDAL_DATA not found""
LIBXML=""2.9.9"" LIBJSON=""0.12""
LIBPROTOBUF=""1.2.1"" WAGYU=""0.5.0 (Internal)"" (core procs from ""3.2.2
3.2.2"" need upgrade)     <== !!! 3.2.2 NEED UPGRADE !!!
RASTER (raster lib from ""2.5.2 r17328"" need upgrade) [UNPACKAGED!]
(raster procs from ""2.5.2 r17328"" need upgrade)"
-- ALTER EXTENSION postgis UPDATE;
Query returned successfully in 599 msec.
NOTICE:  version "3.2.3" of extension "postgis" is already installed
ALTER EXTENSION
Query returned successfully in 160 msec.
-- SELECT * FROM pg_available_extensions WHERE name LIKE 'postgis%';
"name" "default_version" "installed_version" "comment"
"postgis" "3.2.3" "3.2.3" "PostGIS geometry and geography spatial types and
functions"
"postgis_raster" "3.2.3" <null> "PostGIS raster types and functions"
-- DROP TYPE IF EXISTS public.raster CASCADE;         <== DROPPED THE
RASTER TYPE WITH CASCADE OPTION !!!  I KNOW SHOULD NOT HAVE DONE THAT BUT
THIS IS JUST A TEST !!!
-- SELECT postgis_extensions_upgrade();
"postgis_extensions_upgrade"
"Upgrade completed, run SELECT postgis_full_version(); for details"
NOTICE:  Extension postgis_raster is not available or not packagable for
some reason
NOTICE:  Extension postgis_sfcgal is not available or not packagable for
some reason
NOTICE:  Extension postgis_topology is not available or not packagable for
some reason
NOTICE:  Extension postgis_tiger_geocoder is not available or not
packagable for some reason
Successfully run. Total query runtime: 129 msec.
1 rows affected.
-- CREATE EXTENSION postgis_raster;
ERROR:  PostGIS Raster is already installed in schema 'public'
CONTEXT:  PL/pgSQL function inline_code_block line 10 at RAISE
SQL state: P0001
-- ALTER EXTENSION postgis_raster UPDATE;
ERROR:  extension "postgis_raster" does not exist
SQL state: 42704
-- DROP EXTENSION postgis_raster;
SQL state: 42704
Thanks for the assistance.
Marcelo Marques
Principal Product Engineer | Esri | www.esri.com
On Wed, Aug 31, 2022 at 11:58 AM Marcelo Marques <marcelosmbr at gmail.com>
wrote:
> oh my. sorry. forgot the '%'  thanks for catching that. Thanks a lot. :)
> On Wed, Aug 31, 2022 at 11:25 AM Regina Obe <lr at pcorp.us> wrote:
>> Marcelo,
>> I think it’s your query and below behavior you describe as I understand
>> it seems correct.
>> And your output is correct:
>> GDAL=""GDAL 3.4.3, released 2022/04/22 GDAL_DATA not found""
>> LIBXML=""2.9.9"" LIBJSON=""0.12"" LIBPROTOBUF=""1.2.1"" WAGYU=""0.5.0
>> (Internal)"" RASTER"
>> Instead of:
>> SELECT * FROM pg_available_extensions WHERE name LIKE 'postgis';
>> Should be:
>> And then the postgis_raster should show along with postgis_topology and
>> postgis_sfcgap and postgis_tiger_geocoder.
>> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
>> Behalf Of *Marcelo Marques
>> *Sent:* Wednesday, August 31, 2022 2:03 PM
>> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
>> *Subject:* Re: [postgis-users] extension "postgis_raster" has no
>> -- Yes, I have Postgis 3.2.2 for PostgreSQL 11 installed and it already
>> contain a file named "postgis--unpackaged--3.2.2.sql" under "C:\Program
>> Files\PostgreSQL\11\share\extension"
>> C:\Program Files\PostgreSQL\11\share\extension>dir postgis--unpackaged*.*
>>  Directory of C:\Program Files\PostgreSQL\11\share\extension
>> 03/11/2019  12:12 PM         1,475,393 postgis--unpackaged--2.5.2.sql
>> 07/30/2022  12:49 AM         1,068,869 postgis--unpackaged--3.2.2.sql
>> 08/30/2022  04:14 PM                21 postgis--unpackaged.sql
>> -- I compared the file C:\Program
>> Files\PostgreSQL\11\share\extension\postgis--unpackaged--3.2.2.sql on my
>> server
>> -- with the one from
>> https://winnie.postgis.net/download/windows/pg11/buildbot/extras/postgis--unpackaged--3.2.2.sql
>> -- and they are identical.
>> -- and still fails to upgrade.
>> some reason
>> NOTICE:  Packaging extension postgis_raster
>> ERROR:  extension "postgis_raster" has no installation script nor update
>> CONTEXT:  SQL statement "CREATE EXTENSION postgis_raster SCHEMA public
>> VERSION unpackaged;ALTER EXTENSION postgis_raster UPDATE TO "3.2.2""
>> PL/pgSQL function postgis_extensions_upgrade() line 71 at EXECUTE
>> SQL state: 22023
>> -- I followed you suggestion and installed Postgis 3.2.3 for PostgreSQL 11
>> -- I checked and PostGIS 3.2.3 has the empty file "C:\Program
>> Files\PostgreSQL\11\share\extension\postgis--unpackaged.sql"
>> -- This file just has text "-- Nothing to do here"
>> C:\Program Files\PostgreSQL\11\share\extension>dir postgis--unpa*.*
>> 08/19/2022  04:24 PM         1,465,258 postgis--unpackaged--3.2.3.sql
>> -- I was able to upgrade the postgis extension
>> -- and upgrade the raster extension and then
>> -- remove the raster extension and
>> -- if I want I can reinstall postgis_raster extension
>> ALTER EXTENSION
>> NOTICE:  Updating extension postgis from 3.2.2 to 3.2.3
>> some reason
>> WARNING:  'postgis.gdal_datapath' is already set and cannot be changed
>> until you reconnect
>> WARNING:  'postgis.gdal_enabled_drivers' is already set and cannot be
>> changed until you reconnect
>> WARNING:  'postgis.enable_outdb_rasters' is already set and cannot be
>> for some reason
>> Successfully run. Total query runtime: 1 secs 884 msec.
>> 1 rows affected.
>> -- SELECT * FROM pg_available_extensions WHERE name LIKE 'postgis';
>> and functions"
>> ERROR:  extension "postgis_raster" already exists
>> SQL state: 42710
>> -- NOTE: if postgis_raster already exists then pg_available_extensions
>> should have showed that, seems another bug to fix !!!
>> DROP EXTENSION
>> Query returned successfully in 125 msec.
>> (Internal)"""
>> --NOTE: RASTER EXTENSION REMOVED !!!
>> -- Try to install postgis_raster extension
>> CREATE EXTENSION
>> Query returned successfully in 252 msec.
>> and functions"
>> --NOTE: pg_available_extensions still does not show postgis_raster but in
>> pgAdmin when expand the "Extensions" I can see "postgis" and
>> "postgis_raster".
>> DROP EXTENSION
>> I appreciated your assistance.
>> Thanks,
>> Marcelo
>> On Tue, Aug 30, 2022 at 8:42 PM Regina Obe <lr at pcorp.us> wrote:
>> I guess my attachment was too big.
>> Here is a link to it if you need it,
>> but if you are running a patched PostgreSQL 11, you’ll really need to be
>> using the PostGIS 3.2.3 install which you can get from application
>> stackbuilder or https://download.osgeo.org/postgis/windows/pg11/
>> Hope that helps,
>> Regina
>> *From:* Regina Obe [mailto:lr at pcorp.us]
>> *Sent:* Tuesday, August 30, 2022 8:00 PM
>> *To:* 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>
>> *Subject:* RE: [postgis-users] extension "postgis_raster" has no
>> Attached is the one for 3.2.2
>> But that is in my artifacts so should have already been installed by your
>> setup.  Do you have the attached file in your share/extension folder?
>> *From:* Regina Obe [mailto:lr at pcorp.us <lr at pcorp.us>]
>> *Sent:* Tuesday, August 30, 2022 7:56 PM
>> Oh you are running 3.2.2 and not 3.2.3.  I know 3.2.3 has this file
>> postgis_raster--unpackaged--3.2.3.sql
>> which is what you are missing.
>> Can you install 3.2.3?  Then once you install the binaries, run again and
>> it should work.
>> <postgis-users-bounces at lists.osgeo.org>] *On Behalf Of *Marcelo Marques
>> *Sent:* Tuesday, August 30, 2022 7:39 PM
>> Hello Regina,
>> I tried but the upgrade still failed, see below.
>> --create an empty file named "postgis--unpackaged.sql" in your
>> share/extension folder of your PostgreSQL install.
>> --This file just has text
>> --C:\Program Files\PostgreSQL\11\share\extension folder
>> --And then try your upgrade again.
>> --SELECT postgis_extensions_upgrade();
>> some reason
>> SQL state: 22023
>> --SELECT * FROM pg_available_extensions WHERE name LIKE 'postgis';
>> "postgis" "3.2.2" "3.2.2" "PostGIS geometry and geography spatial types
>> and functions"
>> --only the postgis extension is installed!!!
>> --CREATE EXTENSION postgis_raster;
>> ERROR: PostGIS Raster is already installed in schema 'public' CONTEXT:
>> PL/pgSQL function inline_code_block line 10 at RAISE SQL state: P0001
>> --SELECT postgis_full_version();
>> "POSTGIS=""3.2.2 3.2.2"" [EXTENSION] PGSQL=""110""
>> (Internal)""
>> Marcelo
>> On Tue, Aug 30, 2022 at 3:56 PM Regina Obe <lr at pcorp.us> wrote:
>> Marcelo,
>> Apologies, this file was left out in my packaging.  I’ll create an
>> updated package later this week to fix this issue and will also have a
>> 3.3.0 which doesn’t have this issue.
>> I’ve updated ticket to reflect.
>> Copy  the attached file (which is essentially an empty file)  into your
>> Sorry for the omission,
>> Regina
>> *Sent:* Tuesday, August 30, 2022 6:08 PM
>> *To:* postgis-users at lists.osgeo.org
>> *Subject:* [postgis-users] extension "postgis_raster" has no
>> Hello,
>> I am trying to get a workaround for the problem below.
>> see more details in this link
>> https://trac.osgeo.org/postgis/ticket/5222#ticket
>> Have you encountered this issue before? If yes, do you know how to fix it
>> Thanks,
>> | *Marcelo Marques *| Esri PS Products | Principal Product Engineer |
>> postgis-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220831/fe6ad9aa/attachment.htm>
