[postgis-users] RES: Clipping a raster and a polygon using ST_Intersection
Regina Obe
lr at pcorp.us
Tue Dec 6 12:03:06 PST 2022
ST_Resize might be a better option
https://postgis.net/docs/RT_ST_Resize.html
ST_Resize takes in raster width/height similar to ST_Resample.
Sent: Tuesday, December 6, 2022 2:53 PM
To: 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>
Cc: 'liglio.pessoal at nexxa.com.br' <liglio.pessoal at nexxa.com.br>
Subject: RE: [postgis-users] RES: Clipping a raster and a polygon using
ST_Intersection
> Each pixel is associated with a value in the original raster, and when you
do resample, what value is associated to the pixels (in the docs New pixel
values are computed using the NearestNeighbor).
So in your example x5, only one pixel has the original pixel value and the
others 24 pixels has zero or nodata ? If I do colored scale of values it not
seems right.
Hmm that is not what I was expecting. Then again I always use the function
to reduce resolution, and not for this particular purpose. I had assumed it
would apply the value to the next neighboring and keep on applying that way.
But sounds like I was wrong about that.
I think I was confusing that with ST_Rescale. Try using ST_Rescale instead
and see if that gives expected results.
Note ST_Rescale takes as input pixel sizes. In your case you want to reduce
the size of each pixel. The below reduces the pixel size by 20%
https://postgis.net/docs/RT_ST_Rescale.html
SELECT ST_Clip( ST_Rescale(rast, ST_PixelWidth(rast)*0.2,
ST_PixelHeight(rast)*0.2 ) , c. area_country)
FROM country AS c
INNER JOIN tb_densitysurface AS d
ON ( ST_Intersects(d.rast, c.area_country) )
WHERE c.gid = 19;
Another question: I do a retangular matrix larger than the country (creating
an empty raster and dumping each pixel as polygon, and counting lightining
inside each sqare). So I have a lot of squares to compute, and 20 years of
lightining (about 2 billions).
It will be more efficient/faster if my empty raster has the shape of my
country, so It will have less squares to compute. It is possible ?
Yes it would be more efficient both in space and time for computing.
Just clip your raster by the country boundaries kind of like you were doing.
So something like
CREATE TABLE tb_densitysurface _country_clip AS
SELECT s.rid, ST_Clip(s.rast, geom) AS rast
FROM tb_densitysurface AS s CROSS JOIN (SELECT ST_Union(area_country) AS
geom FROM country_boundaries) AS c;
I recall you said you had just one raster, if you have multiple, then you
should change the above an INNER JOIN
ST_Intersects(s.rast, c.geom). If you only care about one country, you can
clip to that one country.
The only reason I am unioning is so you dont end up with duplicate rasters
at country boundaries.
Hope that helps,
Regina
From: liglio.pessoal at nexxa.com.br <mailto:liglio.pessoal at nexxa.com.br>
[mailto:liglio.pessoal at nexxa.com.br]
Sent: Tuesday, December 6, 2022 2:20 PM
To: 'Regina Obe' <lr at pcorp.us <mailto:lr at pcorp.us> >
Subject: RES: [postgis-users] RES: Clipping a raster and a polygon using
ST_Intersection
Regina,
Thank you very much for your reply, and by the way congratulations for your
book PostGis in action third edition, I bought and it is very good.
Just occurred to me that the ST_Intersection I gave you earlier probably
does much the same as ST_Clip
R: Yes is pretty much the same. The result image is the same.
seems right.
Regards,
Liglio
De: Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> >
Enviada em: segunda-feira, 5 de dezembro de 2022 13:25
Para: 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org
<mailto:postgis-users at lists.osgeo.org> >
Cc: liglio.pessoal at nexxa.com.br <mailto:liglio.pessoal at nexxa.com.br>
Assunto: RE: [postgis-users] RES: Clipping a raster and a polygon using
ST_Intersection
does much the same as ST_Clip.
That said, you should be able to achieve a less choppy result using
ST_Resample and ST_Clip in unison.
Increase the 5 to as much as you need to get the less choppy effect you are
looking for.
SELECT ST_Clip( ST_Resample(rast, ST_Width(rast)*5, ST_Height(rast)*5 ) , c.
area_country)
FROM country AS c
WHERE c.gid = 19;
Sent: Sunday, December 4, 2022 12:10 PM
<mailto:liglio.pessoal at nexxa.com.br> >
ST_Intersection
Liglio,
b1 being choppier than b2, is because the rasterized polygon takes on the
pixel size of your low res polygon.
Id try resampling your tb_densitysurface to lower pixel size before you do
the operation with ST_Resample.
https://postgis.net/docs/RT_ST_Resample.html
The width and height are measured in pixels. The idea is you want your
tb_densitysurface to have more pixels than it does now so that the size of
each pixel is smaller.
If you do something like
CREATE TABLE tb_densitysurface_x5 AS
SELECT rid, ST_Resample(rast, ST_Width(rast)*5, ST_Height(rast)*5 ) AS rast
FROM tb_densitysurface;
That should give you the same spatial ref sys, but the pixels will be
smaller in size.
You can then use this to rerun the ST_Intersection in raster space.
I think it will be a little slower though, because the more pixels you have
the slower things get.
Just keep on increasing that number 5 until you get something that meets
your choppiness criteria.
As you get less choppy, operations will get slower, so you need to find a
sweet spot there.
Regarding: There is a way to export this image and associate a value for
each square (polygon) to be colored accordingly ?
Was that to resolve the above issue, or you just want to know.
Well there is ST_PixelAsPolygons which will convert each pixel to a square
polygon. https://postgis.net/docs/RT_ST_PixelAsPolygons.html
There is also ST_DumpAsPolygons
https://postgis.net/docs/RT_ST_DumpAsPolygons.html which tries to aggregate
nearby pixels with the same value into a polygon.
Both return geomval rows similar to the ST_Intersection of raster, geom. As
I recall I think those were completely rewritten in C so should still be
faster than ST_Intersection(geometry,raster).
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of liglio.pessoal at nexxa.com.br <mailto:liglio.pessoal at nexxa.com.br>
Sent: Wednesday, November 30, 2022 9:37 AM
Subject: [postgis-users] RES: Clipping a raster and a polygon using
ST_Intersection
Regina,
Thanks for your replay.
Your solution is fast like using ST_Clip, but I still have the problem that
my pixels are 25km square (low definition) and the image look like this:
(image b1.jpg)
And I want to produce something like this: (image b2.jpg)
I know that the second image cannot be reproduced as just raster with big
pixels, the pixels cannot be cutted.
There is a way to export this image and associate a value for each square
Regards,
Liglio
De: postgis-users <postgis-users-bounces at lists.osgeo.org
<mailto:postgis-users-bounces at lists.osgeo.org> > Em nome de Regina Obe
Enviada em: quinta-feira, 24 de novembro de 2022 12:19
Assunto: Re: [postgis-users] Clipping a raster and a polygon using
ST_Intersection
Im not quite sure what you mean by edges arent smooth. Rasters are never
really smooth. Vectors are smooth. Rasters may look smooth at the edges,
but thats more because pixels are square and the pixels in each tile line
up with the pixels.
If you want it to look a little smoother, maybe expand your envelop ever so
slightly so it lines up with a pixel in a raster. So each edge pixel is
guaranteed to be fully inside the raster and no edge partly outside the
raster or do the operation in raster space which I will explain shortly.
ST_Intersection yes is known to be very slow and as you noticed does not
give you a raster back.
Is ST_Clip + ST_Intersects performance sufficient for your needs?
ST_Clip really is ST_Intersection in raster space for raster/geometry. So
you could do the intersection in pure raster space by converting your
geometry to a raster (making sure to align your new raster with your
reference raster). That should make the edges smooth.
Like so not tested so might have some syntax errors and also I havent
used this in a very long time so may be wrong about what it returns.
SELECT ST_Intersection(r.rast, r2.rast) AS new_rast
FROM tb_densitysurface AS r, country,
-- create a raster to represent the country that has the same alignment as
our density raster (pixels use the same grid)
ST_AsRaster( country.area_country, r.rast, '1BB', 0) AS
r2(rast)
WHERE country.gid = 19 AND ST_Intersects(r.rast, r2.rast)
) As foo
As far as tiling goes, yah that would improve the smoothness of the inner
tiles but not most outer ones.
Youd also need to ST_Union them all up to get back to a single tile which
will add perhaps more overhead than just keeping as single tile.
If you want to tile your raster, you can use this function -
https://postgis.net/docs/manual-2.5/RT_ST_Tile.html
Hope that helps,
Regina
Sent: Tuesday, November 22, 2022 2:00 PM
To: postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
Subject: [postgis-users] Clipping a raster and a polygon using
ST_Intersection
I created a retangular raster representing number of lightnings in a square.
So I have this matrix raster created using ST_MapAlgebraFct and
ST_MakeEmptyRaster.
This raster is not a tiled raster (tb_densitysurface), and when I Clip this
raster using a polygon, the query below, the performance is not good.
Maybe because the raster is not tiled. So how do I tile this raster ? And I
want the result to be a raster (not gval) to be exported as a file, and then
colored using GDAL.
It worked with a different query only using ST_Clip (this returns a rast
column and is very fast), but the edges aren´t smooth as using
ST_Insersection. I am using Postgis 2.5.
SELECT
(gval).val
(gval).geom
FROM (
ST_Clip(rast,ST_Envelope(area_country)),
1,
area_country
) As gval
FROM country, tb_densitysurface WHERE ST_Intersects(rast, area_country)
and country.gid = 19
) As foo
Regards,
Liglio
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20221206/1f12973c/attachment.htm>
