[postgis-users] Row estimations
Regina Obe lr at pcorp.us
Mon Dec 12 19:17:34 PST 2022
Paul,
Is it the same story with ST_CoveredBy and ST_Covers.  I care more about
those than ST_Contains and ST_Within.
Maybe part of the reason it hasn't been brought up if it is a really old
issue, is most people just use ST_Intersects or ST_DWithin.
In my case when I care about polygon boundaries I lean more on ST_CoveredBy
and ST_Covers than I do on ST_Contains and ST_Within.
This ticket looks like it might be a possible complaint of the issue.
https://trac.osgeo.org/postgis/ticket/4754
That suggests it's an issue of PostGIS 3+
I thought we had others too about ST_covers but can't find any open ones.
> -----Original Message-----
> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On
Behalf
> Of Paul Ramsey
> Sent: Monday, December 12, 2022 5:57 PM
> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> Subject: Re: [postgis-users] Row estimations
> From what I've been able to find out today, this bug may have existed for
a
> very long time. Firstly, the selectivity calculation is correct (using
your test
> setup).
> =# select _postgis_selectivity('test'::regclass, 'p', 'POLYGON((0
> 0,0.8 0,0.8 0.8,0 0.8,0 0))');
>    0.7886187126157185
> That seems to be the selectivity applied in the ST_Intersects plan, but
not in
> the ST_Contains plan.
> Now, both ST_Intersects and ST_Contains are "index assisted"
> functions. Under the covers, we add index operators to them before they
are
> planned. Before PgSQL 12, this was done with a SQL wrapper, and since then
> with a "support function". In both cases though, the effect is to add an
> operator to the query.
> For ST_Intersects, && is added. For ST_Contains, @ is added. And here we
get
> into the problem... if you look at the definitions of && and @, you'll see
this.
> CREATE OPERATOR && (
>     LEFTARG = geometry, RIGHTARG = geometry, PROCEDURE =
> geometry_overlaps,
>     COMMUTATOR = '&&',
>     RESTRICT = gserialized_gist_sel_2d,
>     JOIN = gserialized_gist_joinsel_2d
> CREATE OPERATOR @ (
> geometry_within,
>     COMMUTATOR = '~',
>     RESTRICT = contsel, JOIN = contjoinsel );
> The && operator is using the PostGIS selectivity calculator to estimate
rows
> returned. The @ operator is using an in-built function that returns a
constant
> (small) selectivity. Effectively pushing the planner to use the index
almost all
> the time.
> For many (most) spatial queries, a selectivity that pushes the plan into
using
> the index is a Good and Correct Thing (tm). But as queries get more
complex
> and involve more tables, the odds that this is the Wrong Thing, go up.
> I'm not sure how long this situation has existed, but I'm inclined to
thing a Very
> Long Time. So I'm surprised we haven't had reports about it before. I'm
also a
> little surprised we didn't apply selectivity calculations to
contains/within a long
> time ago. A simple and effective fix is to replace contsel with
> gserialized_gist_sel_2d for the ~ and @ operators. Unfortunately it's a
hard fix
> to apply in in-place upgrades and in batch patches.
> Anyone who feels like researching the history of selectivity in @/~ by
looking
> at old releases, I'd be interested in knowing how long this situation has
existed.
> (Forever?)
> P.
> On Fri, Dec 9, 2022 at 10:14 AM Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
> > > On Dec 9, 2022, at 10:11 AM, Igor ALBUQUERQUE SILVA <i.albuquerque-
> silva at kayrros.com> wrote:
> > > In this example ST_Contains estimates 785 rows, while ST_Intersect
> estimates 615469 which is closer to the real 621571 rows. Using the
bounding
> box operation I also obtain good estimations, and I also obtain good
> estimations if I don't use the gist index.
> > This still seems Really Bad (tm) in that the contains estimate is still
tragically
> wrong. However, we have at least some clue as to where to hunt for this
bug.
> Thanks for continuing to push the testing forward.
> > P.
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
