[postgis-users] Help shaping the future: how do your use of spatial_ref_sys ?
Robert Coup robert.coup at koordinates.com
Wed Feb 9 05:28:13 PST 2022
Hi Sandro,
On Fri, 4 Feb 2022 at 17:05, Sandro Santilli <strk at kbt.io> wrote:
> The question I have for you is: do you keep your custom CRSs
> in the spatial_ref_sys table ? If so:
Yes.
>   - How many ?
A dozen or so. We use 800xxx numbering for no particular reason, but we try
and avoid exposing that.
>   - Do you also keep the entries installed by spatial_ref_sys.sql ?
Yes
>   - Do you ever update the table with entries from newer
Yes. We keep postgis' spatial_ref_sys synchronised with the Proj DB version
we're running as best we can to make life simpler.
If we're moving things:
1. is spatial_ref_sys redundant for anything non-custom? Proj has a full
database now, why does PostGIS need it's own?
2. proj4text should disappear altogether too. If people have existing
proj4text they want to use... `projinfo -o WKT2:2019 '{my-proj4text}'`
3. Since CUSTOM:4326 and EPSG:4326 clash - the PK is the number; and
SRID-is-integer is part of SF-SQL (ie: that's not going to change anytime
soon) could we at least help people put their custom CRS in the right
place? Is there a defined custom number range we could use to initialise a
sequence?
I think since Proj has gotten a lot smarter since v4, PostGIS should tend
towards helping people use it (supporting pipelines, using it's
DB/transform grids/etc) rather than adding additional abstractions over the
top.
Cheers,
Rob :-)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220209/92235993/attachment.html>
