[postgis-users] Are there script examples for determine where vertices run clockwise or anti-clockwise?
Shaozhong SHI
shishaozhong at gmail.com
Wed Feb 16 12:28:21 PST 2022
The problem now is that I can not find anything for lines.
Anything like ST_IsPolygonCW|ST_IsPolygonCCW for lines for instance,
something like ST_IsLineCW|ST_IsLineCCW.
Regards,
David
On Wed, 16 Feb 2022 at 19:43, Marcin Mionskowski <
mionskowskimarcin at gmail.com> wrote:
> Assuming simple polygons, composed from exterior ring only (i.e. no
> multipolygons), I think that you are looking for a function
> {ST_IsPolygonCW|ST_IsPolygonCCW}.
> Greetings,
> Marcin
> śr., 16 lut 2022 o 19:55 Imre Samu <pella.samu at gmail.com> napisał(a):
>> > how vertices run? clockwise or anti-clockwise?
>> maybe the:
>> https://postgis.net/docs/ST_Angle.html *"Computes the clockwise angle
>> between two vectors."*
>> or https://postgis.net/docs/ST_Azimuth.html
>> regards,
>> Imre
>> Shaozhong SHI <shishaozhong at gmail.com> ezt írta (időpont: 2022. febr.
>> 16., Sze, 17:06):
>>> Can we use PostGIS to find out how vertices run? clockwise or
>>> anti-clockwise?
>>> Regards,
>>> David
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220216/c127d9a3/attachment.html>
