[postgis-users] Non-linear time cost; please suggest a better way to structure the query
Rory Meyer
rory.meyer at VLIZ.be
Wed Feb 23 23:55:54 PST 2022
"You may need to materialize the trajectories so you can spatially index them"
I'll give that a try. I'll wrap my query into a procedure that materialises the trajectories, adds and index, does the work and then drops them. I'm looking at around 2 gigs of data per day, so doing this for large time periods might be a little painful.
Regards,
Rory
From: postgis-users <postgis-users-bounces at lists.osgeo.org> on behalf of Paul Ramsey <pramsey at cleverelephant.ca>
Sent: 23 February 2022 16:36
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] Non-linear time cost; please suggest a better way to structure the query
On Wed, Feb 23, 2022 at 6:14 AM Rory Meyer <rory.meyer at vliz.be<mailto:rory.meyer at vliz.be>> wrote:
Afternoon all,
I've got a database full of GPS points (along with associated data like speed, bearing, time, GPS_ID, class etc) and I'm trying to do complex aggregations with the data. I'm trying to build up a "heatmap" of the data by first creating a grid of polygons using ST_HexagonGrid and then using a window function to overlay the lines (created from a lead/lag window of each GPS point and the next one from the same GPS_ID) over the grid. I'd like to get the the number of seconds that gps carrying vehicles spend in each hex cell, grouped by class, speed, date, direction etc etc. The end goal would be to query a lon/lat and get a bunch of aggregated data for different classes, speed/bearing distributions.
Here's a simplified look at the SQL (sorry, it's not really simple...):
SELECT
grid.gid,
grid.geom,
avg(traj.bearing, 511.0) AS avg_bearing,
avg(traj.time_delta) AS avg_time_delta,
sum(((st_length(st_intersection(traj.traj, grid.geom)) * traj.time_delta) / traj.traj_dist)) AS cum_time_in_grid
FROM (
(my_hex_grid AS grid LEFT JOIN ( SELECT
subquery.gps_id,
subquery.event_date,
subquery.bearing,
subquery.time_delta,
st_makeline(subquery.pos, subquery.pos2) AS traj,
st_distance(subquery.pos, subquery.pos2) AS traj_dist
FROM (
SELECT
gps.mmsi,
date_part('epoch'::text, (lead(gps.event_time) OVER time_order - gps.event_time)) AS time_delta,
gps.geom,
gps.bearing,
lead(gps.geom) OVER time_order AS geom2
FROM gps
WHERE ((gps.event_time >= '<Start Time>') AND (gps.event_time <= '<End Time>'))
WINDOW time_order AS (PARTITION BY gps.gps_id ORDER BY gps.event_time)) as subquery
ON (st_intersects(gps.traj, grid.geom)))
GROUP BY grid.gid, grid.geom
My issue is that I've got a non-linear increase in time that the query takes to complete. If <Start Time> to <End Time> is a couple of hours then it's takes a couple of seconds to run. If it's for a day, it takes a couple minutes to run. If it's for a week it takes a couple of hours.
I'd like to run this for over a year of data but that won't be feasible at this rate.
Is there some way to avoid this non-linear increase in time or would it be best to just write some python code to loop through smaller chunks of data and write the results somewhere?
Regards,
Rory
postgis-users mailing list
postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220224/1f17a0a0/attachment.html>
