[postgis-users] Postgis Raster determine exact hull
Richard Huesken richard.huesken at gmail.com
Mon Jan 10 12:26:40 PST 2022
hi,
I'm using postgis 3.1 and I'm looking for the best way to obtain the exact
hull of a raster (excluding the nodata points). The st_minconvexhull uses
the MBR of the raster coverage, and is therefore quite fast. The result is
however not as accurate as I require.
I constructed some sql that uses st_pixelaspolygons and then does a
st_union. However, My typical raster has 256x256 points, and with several
100s of rasters this is quite slow.
Are there more clever (and faster!) ways to get the exact hull of a raster?
Thanks in advance,
Richard.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220110/ada538a6/attachment.html>
