[postgis-users] Postgis Raster determine exact hull
Marcin Mionskowski mionskowskimarcin at gmail.com
Mon Jan 10 21:42:48 PST 2022
Try to reclassify the raster first so that all "non NA" values are equal
(e.g. 1), then do ST_DumpAsPolygons.
Regards,
Marcin
pon., 10 sty 2022 o 21:27 Richard Huesken <richard.huesken at gmail.com>
napisał(a):
> hi,
> I'm using postgis 3.1 and I'm looking for the best way to obtain the exact
> hull of a raster (excluding the nodata points). The st_minconvexhull uses
> the MBR of the raster coverage, and is therefore quite fast. The result is
> however not as accurate as I require.
> I constructed some sql that uses st_pixelaspolygons and then does a
> st_union. However, My typical raster has 256x256 points, and with several
> 100s of rasters this is quite slow.
> Are there more clever (and faster!) ways to get the exact hull of a raster?
> Thanks in advance,
> Richard.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220111/e288e782/attachment.html>
