[postgis-users] ST_LineMerge
Imre Samu pella.samu at gmail.com
Wed Mar 2 05:33:33 PST 2022
> It appears that ST_LineMerge alters the sequence of vertices
probably related:
"Add possibility to merge lines without changing order of points."
https://trac.osgeo.org/postgis/ticket/4939
Regards,
 Imre
Shaozhong SHI <shishaozhong at gmail.com> ezt írta (időpont: 2022. márc. 2.,
Sze, 14:21):
> It appears that ST_LineMerge alters the sequence of vertices when a set of
> line geometries that meet at ends are merged together.
> ST_LineMerge (postgis.net) <https://postgis.net/docs/ST_LineMerge.html>
> Any robust way to do the following?
> Given a set of lines that meet at ends
> Generate a new line by merging these together and maintain the original
> order of vertices
> Regards,
> David
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220302/84a0adab/attachment.html>
