[postgis-users] Cut extent box2d into small regular boxes, and iterate through each box of features
Shaozhong SHI
shishaozhong at gmail.com
Mon Mar 28 01:02:16 PDT 2022
Hello, Lars,
This is interesting.
Can you expand on this content_balanced_grid and how to generate it?
I can test this approach out.
Regards,
David
On Mon, 28 Mar 2022 at 07:49, Lars Aksel Opsahl <Lars.Opsahl at nibio.no>
wrote:
> >From: postgis-users <postgis-users-bounces at lists.osgeo.org> on behalf of
> Mike Taves <mwtoews at gmail.com>Sent: Sunday, March 27, 2022 10:31 PMTo:
> PostGIS Users Discussion <postgis-users at lists.osgeo.org>Subject: Re:
> >On Sat, 26 Mar 2022 at 02:44, Shaozhong SHI <shishaozhong at gmail.com>
> wrote:
> >> Is there a procedure to get a box2d for the extent of features?
> >> Divide the box into smaller regular boxes
> >> loop carry out geospatial operation in each box
> >A few ideas to generate the small regular boxes, see:
> >- https://postgis.net/docs/ST_SquareGrid.html
> >- https://gis.stackexchange.com/q/16374/
> Hi
> We use a lot of grids, but we have seen that using content to influence
> each grid cell size is more important than having regular sized grid cell.
> For instance, smaller cell's where it's high density of polygons and larger
> cell in other areas. When grid cells are "equal" related to content (and
> not spatial size) it also easier to run thing parallel without running into
> memory problems and so on.
> Here is some sample code https://github.com/larsop/content_balanced_grid
> to create grids and here some code where we use such a grid
> https://github.com/larsop/find-overlap-and-gap .
> Lars
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220328/30edaabd/attachment.html>
