[postgis-users] Recursive query - ERROR: invalid memory alloc request size 1073741824
Shaozhong SHI
shishaozhong at gmail.com
Sat May 7 18:37:37 PDT 2022
Testing shows that using startnode and endnode of id values of a line does
lead to a fast completion of processing.
However, at the moment, I am not sure whether these startnode (id values)
and endnode (id values) are correct.
I am thinking of generating startnode and endnode values by using
St_startpoint(geom) and ST_endpoint(geom),
And then try out your alternative method for recursive query to see whether
walk the network works.
Is this feasible?
Regards,
David
On Sun, 8 May 2022 at 00:59, Imre Samu <pella.samu at gmail.com> wrote:
> Hi David,
> > There is a loop of recursive query. It runs at a point where it stops.
> >Can anyone provide pointers how to solve this problem or work around?
> Please share "this" recursive query;
> My guess: Probably you have a "forever/endless loop" in your data; *so
> you have to LIMIT the recursive part ;*
> related links :
> 1.) with limiting "depth" ( where depth < 1000 )
> "Prevent infinite loop in recursive query in Postgresql"
> https://stackoverflow.com/questions/51025607/prevent-infinite-loop-in-recursive-query-in-postgresql
> 2.) with LIMITING clause
> https://www.cybertec-postgresql.com/en/recursive-queries-postgresql/
> *"This example also demonstrates how an endless loop can be avoided with a
> LIMIT clause on the parent query."*
> Regards,
> Imre
> Shaozhong SHI <shishaozhong at gmail.com> ezt írta (időpont: 2022. máj. 7.,
> Szo, 15:23):
>> This error turned up.- ERROR: invalid memory alloc request size
>> 1073741824
>> Regards,
>> David
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220508/a46ffb6b/attachment.htm>
