[postgis-users] Recursive query - ERROR: invalid memory alloc request size 1073741824
Imre Samu pella.samu at gmail.com
Sat May 7 19:18:52 PDT 2022
> I am thinking of generating startnode and endnode values by using
St_startpoint(geom) and ST_endpoint(geom),
> Is this feasible?
if your input data is “noded” correctly - then YES ...
“noded” network =  at every intersection in your road/water network all the
edges will be broken into separate road/water segments.
And you have to assign the same "node id" for the same physical points.  (
ST_DWithin magic )
be careful:  The "Network Walking" example was a nodded network ( without
an intersection! )
maybe you can test the https://postgis.net/docs/CreateTopology.html
function also;
Imre
Shaozhong SHI <shishaozhong at gmail.com> ezt írta (időpont: 2022. máj. 8., V,
3:38):
> Testing shows that using startnode and endnode of id values of a line does
> lead to a fast completion of processing.
> However, at the moment, I am not sure whether these startnode (id values)
> and endnode (id values) are correct.
> And then try out your alternative method for recursive query to see
> whether walk the network works.
> Is this feasible?
> Regards,
> David
> On Sun, 8 May 2022 at 00:59, Imre Samu <pella.samu at gmail.com> wrote:
>> Hi David,
>> > There is a loop of recursive query.  It runs at a point where it stops.
>> >Can anyone provide pointers how to solve this problem or work around?
>> Please share "this" recursive query;
>> My guess:  Probably you have a "forever/endless loop" in your data; *so
>> you have to LIMIT the recursive part ;*
>> related links :
>> 1.)  with limiting "depth"   ( where depth < 1000 )
>> "Prevent infinite loop in recursive query in Postgresql"
>> https://stackoverflow.com/questions/51025607/prevent-infinite-loop-in-recursive-query-in-postgresql
>> 2.)  with LIMITING clause
>> https://www.cybertec-postgresql.com/en/recursive-queries-postgresql/
>> *"This example also demonstrates how an endless loop can be avoided with
>> a LIMIT clause on the parent query."*
>> Regards,
>>   Imre
>> Shaozhong SHI <shishaozhong at gmail.com> ezt írta (időpont: 2022. máj. 7.,
>> Szo, 15:23):
>>> This error turned up.- ERROR:  invalid memory alloc request size
>>> 1073741824
>>> Regards,
>>> David
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220508/90f1ea74/attachment.htm>
