[postgis-users] Problem with raster2psql out-db
Regina Obe
lr at pcorp.us
Wed Nov 9 19:29:11 PST 2022
The out_db constraint is not filled in unless you include the –C option to include constraints.
So I suspect your raster loaded is really out of database.
An easy way to check is run a query like this described on this page: https://postgis.net/docs/manual-3.3/RT_ST_BandMetaData.html
SELECT bmd.out_db, bmd.path
FROM t1 AS r, ST_BandMetaData(r.rast) AS bmd LIMIT 1;
You can add an out_db constraint with this function - https://postgis.net/docs/manual-3.3/RT_AddRasterConstraints.html
Like so:
SELECT AddRasterConstraints('t1', 'rast', 'out_db' );
Hope that helps,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Alex German
Sent: Wednesday, November 9, 2022 12:51 AM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] Problem with raster2psql out-db
Hi, everybody.
I need help.
I have a problem when using the raster2psql utility.
I use the -R key, but the raster is loaded into the raster table, and not as an external file. raster_columns in the out_db field is null
raster2pgsql -R //geoserver/t1.tif | psql
What am I doing wrong?
Alex German
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20221109/2b2d192e/attachment.htm>
