[postgis-users] No extension
Simon Greener
simon at spdba.com.au
Tue Oct 4 13:57:03 PDT 2022
Search path is set. Because it is set in the database it is independent of the port, correct?
Because I need to move forward, I've gone back to using port 5433 and all is working.
Thanks to all for taking the time to help.
Simon
39 Cliff View Drive
Allens Rivulet Tas 7150
(W) 0418 396 391
On 5 Oct 2022, 06:09, at 06:09, Bo Victor Thomsen <bo.victor.thomsen at gmail.com> wrote:
>What about search path for Postgres ? It could be different for each
>client accessing Postgres.
>Den 03-10-2022 kl. 20:27 skrev Regina Obe:
>> That is weird. I would have thought maybe a JDBC driver issue, but
>the error suggests it was able to connect and just not able to access
>that function. Or that error is just bogus and it really can't
>connect.
>> 1) Is it using the same account as other apps. Could be a permission
>issue.
>> 2) Can you do a quick non-postgis test like?
>> SELECT version();
>> 3) I know there were big changes between PG 11 / PG 12 that
>necessitated upgrades of drivers, but didn't think much difference
>between PG13 and PG14. If option 1 and 2 were not useful, I'd suggest
>just upgrading to the latest JDBC driver from
>https://jdbc.postgresql.org/download/
>>> -----Original Message-----
>>> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org]
>On Behalf
>>> Of Simon Greener
>>> Sent: Friday, September 30, 2022 4:56 AM
>>> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
>>> Subject: Re: [postgis-users] No extension
>>> Yes, it is uninstalled.
>>> ?39 Cliff View Drive
>>> (W) 0418 396 391?
>>> On 30 Sep 2022, 18:24, at 18:24, Alexandre Neto
><senhor.neto at gmail.com>
>>> wrote:
>>>> Did you uninstall PostgreSQL 13?
>>>> A sexta, 30/09/2022, 04:08, Simon SPDBA Greener
><simon at spdba.com.au>
>>>> escreveu:
>>>>> I decided to switch the port back to 5432 following your recipe
>>>> (because
>>>>> I have many apps that access postgresql).
>>>>> I can connect using qGIS/pgAdmin 4 etc but when I try to connect
>>>> using
>>>>> GeoServer I get this:
>>>>> at java.base/java.lang.Thread.run(Thread.java:831)
>>>>> Caused by: java.lang.RuntimeException: Unable to obtain
>connection:
>>>>> ERROR: function postgis_lib_version() does not exist
>>>>> Hint: No function matches the given name and argument types.
>You
>>>>> might need to add explicit type casts.
>>>>> Position: 8
>>>>> at
>org.geotools.jdbc.JDBCDataStore.createConnection(JDBCDataStore.java:213
>>>> 2)
>>>>> Running the function in pgAdmin 4 returns:
>>>>> select postgis_lib_version();
>>>>> "postgis_lib_version"
>>>>> "3.2.3"
>>>>> Any ideas?
>>>>> All other apps work correctly, only GeoServer is returning this
>>>> error.
>>>>> regards
>>>>> Simon
>>>>> On 30/09/2022 11:39 am, Simon SPDBA Greener wrote:
>>>>>> The old postgresql 13 was running on 5432.
>>>>>> I thought I had shut it down before running the 14 installer.
>>>>>> No matter, your suggestion about 5433 was the key I needed to
>open
>>>> the
>>>>>> door.
>>>>>> Thanks for all your patience and help: greatly appreciated.
>>>>>> regards
>>>>>> Simon
>>>>>> On 30/09/2022 10:31 am, Regina Obe wrote:
>>>>>>> When you use the PostgreSQL installer on windows, If you have a
>>>>>>> PostgreSQL instance running already on Port 5432, it defaults
>the
>>>>>>> port to the next available increment port.
>>>>>>> So my guess is you had your bitnami running on Port 5432, it
>>>> detected
>>>>>>> that,
>>>>>>> so then installed on Port 5433.
>>>>>>> So your old would have 5432, your new PostgreSQL 14 would be
>5433.
>>>>>>> That's why I mentioned, if you wanted it to run on default
>>>> PostgreSQL
>>>>>>> 5432,
>>>>>>> you can do the
>>>>>>> Run the sql:
>>>>>>> ALTER SYSTEM Set port = '5432';
>>>>>>> Then restart the service.
>>>>>>> And that registry change I mentioned.
>>>>>>> Open regedit.exe
>>>>>>> HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Services\postgresql-
>>> x64-14\
>>>>>>> Key: Port
>>>>>>> The registry change you do so if you install other extensions
>such
>>>> as
>>>>>>> postgis or pgAgent that need to connect to the database, they
>read
>>>>>>> the port number from the registry and default to that. I think
>>>>>>> pgAdmin4
>>>> also
>>>>>>> when you
>>>>>>> first setup reads port from registry.
>>>>>>>> From: postgis-users
>>>> [mailto:postgis-users-bounces at lists.osgeo.org] On
>>>>>>> Behalf
>>>>>>>> Of Simon SPDBA Greener
>>>>>>>> Sent: Thursday, September 29, 2022 7:50 PM
>>>>>>>> To: postgis-users at lists.osgeo.org
>>>>>>>> Hold that thought.
>>>>>>>> Port 5432 didn't work on DFDB as I thought it did.
>>>>>>>> Port 5433 works.
>>>>>>>> Has the default port changed with database installs?
>>>>>>>> Simon
>>>>>>>>> Simon Greener
>>>>>>>>> 39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia
>>>>>>>>> (m) +61 418 396 391
>>>>>>>>> (w)www.spdba.com.au
>>>>>>>>> (m)simon at spdba.com.au
>>>>>>>>> _______________________________________________
>>>>>>>>> postgis-users mailing list
>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
>>>>>>>> Simon Greener
>>>>>>>> (m) +61 418 396 391
>>>>>>>> (w) www.spdba.com.au
>>>>>>>> (m) simon at spdba.com.au
>>>>> Simon Greener
>>>>> (m) +61 418 396 391
>Med venlig hilsen / Best regards
>Bo Victor Thomsen
