[postgis-users] No extension
Simon Greener simon at spdba.com.au
Wed Oct 5 02:05:32 PDT 2022
This is most helpful. Thanks. Turns out one app I'm working with is built on GeoTools. I wonder if it does anything with setting/using search paths?
Simon
⁣39 Cliff View Drive
Allens Rivulet Tas 7150
(W) 0418 396 391​
On 5 Oct 2022, 07:55, at 07:55, Regina Obe <lr at pcorp.us> wrote:
>Yah that's one I forgot to mention.
>Search paths can also be set by applications per session, so you might
>want
>to make sure your java app is not doing that.  I've been bitten by that
>with
>some frameworks, where they have a search_path set which is different
>from
>the one I set at the database or user level.
>> -----Original Message-----
>> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On
>Behalf
>> Of Bo Victor Thomsen
>> Sent: Tuesday, October 4, 2022 3:08 PM
>> To: postgis-users at lists.osgeo.org
>> Subject: Re: [postgis-users] No extension
>> What about search path for Postgres ? It could be different for each
>client
>> accessing Postgres.
>> Den 03-10-2022 kl. 20:27 skrev Regina Obe:
>> > That is weird.  I would have thought maybe a JDBC driver issue, but
>the
>error
>> suggests it was able to connect and just not able to access that
>function.
>Or
>> that error is just bogus and it really can't connect.
>> > 1) Is it using the same account as other apps.  Could be a
>permission
>issue.
>> > 2) Can you do a quick non-postgis test like?
>> > SELECT version();
>> > 3) I know there were big changes between PG 11 / PG 12 that
>> > necessitated upgrades of drivers, but didn't think much difference
>> > between PG13 and PG14. If option 1 and 2 were not useful, I'd
>suggest
>> > just upgrading to the latest JDBC driver from
>> > https://jdbc.postgresql.org/download/
>On
>> >> Behalf Of Simon Greener
>> >> Sent: Friday, September 30, 2022 4:56 AM
>> >> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
>> >> Yes, it is uninstalled.
>> >> ?39 Cliff View Drive
>> >> (W) 0418 396 391?
>> >> On 30 Sep 2022, 18:24, at 18:24, Alexandre Neto
>> >> <senhor.neto at gmail.com>
>> >> wrote:
>> >>> Did you uninstall PostgreSQL 13?
>> >>> A sexta, 30/09/2022, 04:08, Simon SPDBA Greener
>> <simon at spdba.com.au>
>> >>> escreveu:
>> >>>> I decided to switch the port back to 5432 following your recipe
>> >>> (because
>> >>>> I have many apps that access postgresql).
>> >>>> I can connect using qGIS/pgAdmin 4 etc but when I try to connect
>> >>> using
>> >>>> GeoServer I get this:
>> >>>>      at java.base/java.lang.Thread.run(Thread.java:831)
>> >>>> Caused by: java.lang.RuntimeException: Unable to obtain
>connection:
>> >>>> ERROR: function postgis_lib_version() does not exist
>> >>>>     Hint: No function matches the given name and argument types.
>> >>>> You might need to add explicit type casts.
>> >>>>     Position: 8
>> >>>>       at
>org.geotools.jdbc.JDBCDataStore.createConnection(JDBCDataStore.java:
>> >>> 213
>> >>> 2)
>> >>>> Running the function in pgAdmin 4 returns:
>> >>>> select postgis_lib_version();
>> >>>> "postgis_lib_version"
>> >>>> "3.2.3"
>> >>>> Any ideas?
>> >>>> All other apps work correctly, only GeoServer is returning this
>> >>> error.
>> >>>> regards
>> >>>> Simon
>> >>>> On 30/09/2022 11:39 am, Simon SPDBA Greener wrote:
>> >>>>> The old postgresql 13 was running on 5432.
>> >>>>> I thought I had shut it down before running the 14 installer.
>> >>>>> No matter, your suggestion about 5433 was the key I needed to
>open
>> >>> the
>> >>>>> door.
>> >>>>> Thanks for all your patience and help: greatly appreciated.
>> >>>>> regards
>> >>>>> Simon
>> >>>>> On 30/09/2022 10:31 am, Regina Obe wrote:
>> >>>>>> When you use the PostgreSQL installer on windows, If you have
>a
>> >>>>>> PostgreSQL instance running already on Port 5432, it defaults
>the
>> >>>>>> port to the next available increment port.
>> >>>>>> So my guess is you had your bitnami running on Port 5432, it
>> >>> detected
>> >>>>>> that,
>> >>>>>> so then installed on Port 5433.
>> >>>>>> So your old would have 5432, your new PostgreSQL 14 would be
>5433.
>> >>>>>> That's why I mentioned, if you wanted it to run on default
>> >>> PostgreSQL
>> >>>>>> 5432,
>> >>>>>> you can do the
>> >>>>>> Run the sql:
>> >>>>>> ALTER SYSTEM Set port = '5432';
>> >>>>>> Then restart the service.
>> >>>>>> And that registry change I mentioned.
>> >>>>>> Open regedit.exe
>> >>>>>> HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Services\postgresql-
>> >> x64-14\
>> >>>>>> Key: Port
>> >>>>>> The registry change you do so if you install other extensions
>> >>>>>> such
>> >>> as
>> >>>>>> postgis or pgAgent that need to connect to the database, they
>> >>>>>> read the port number from the registry and default to that. I
>> >>>>>> think
>> >>>>>> pgAdmin4
>> >>> also
>> >>>>>> when you
>> >>>>>> first setup reads port from registry.
>> >>>>>>> From: postgis-users
>> >>>>>> Behalf
>> >>>>>>> Of Simon SPDBA Greener
>> >>>>>>> Sent: Thursday, September 29, 2022 7:50 PM
>> >>>>>>> Hold that thought.
>> >>>>>>> Port 5432 didn't work on DFDB as I thought it did.
>> >>>>>>> Port 5433 works.
>> >>>>>>> Has the default port changed with database installs?
>> >>>>>>> Simon
>> >>>>>>>> Simon Greener
>> >>>>>>>> 39 Cliff View Drive, Allens Rivulet, 7150, Tasmania,
>Australia
>> >>>>>>>> (m) +61 418 396 391
>> >>>>>>>> (w)www.spdba.com.au
>> >>>>>>>> (m)simon at spdba.com.au
>> >>>>>>>> _______________________________________________
>> >>>>>>>> postgis-users mailing list
>> >>>>>>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
>> >>>>>>> Simon Greener
>Australia
>> >>>>>>> (m) +61 418 396 391
>> >>>>>>> (w) www.spdba.com.au
>> >>>>>>> (m) simon at spdba.com.au
>> >>>> Simon Greener
>> >>>> 39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia
>> >>>> (m) +61 418 396 391
>> Med venlig hilsen / Best regards
>> Bo Victor Thomsen
