[postgis-users] ERROR: type "raster" is only a shell
Marcelo Marques
marcelosmbr at gmail.com
Wed Sep 7 17:03:35 PDT 2022
Thanks Regina. It makes sense now. I appreciated the detailed explanation.
You are the best. Thanks again, Marcelo :)
On Wed, Sep 7, 2022 at 3:21 PM Regina Obe <lr at pcorp.us> wrote:
> The below *ERROR: type "raster" is only a shell* is usually not an error
> but a NOTICE that tells you the raster type has not been defined yet. It
> happens when functions using the raster type are created before the raster
> type is created. As long as the raster type is created before the install
> is complete, then it does not error, and might show as a NOTICE.
> The fact it shows as an error in your case
> Suggests to me, 3 possible scenarios
> a) You managed to get yourself into a state where you have no raster type,
> which should be impossible if you are doing an upgrade of raster, unless
> you did some Frankenstein surgery on your raster, as people often do when
> they panic and see the “Raster is unpackaged” message and start deleting
> stuff randomly.
> Like with a command
> DROP TYPE raster CASCADE;
> If this is the scenario you have, you’ve already destroyed any raster data
> you had, so best course of action is still
> -- uninstall postgis_raster
> psql
> \c rev
> \i 'C:\\Program Files\\PostgreSQL\\12\\share\\contrib\\postgis-3.2\\
> *uninstall_rtpostgis.sql*'
> b) You did this when you actually had no postgis_raster installed at all.
> *CREATE EXTENSION postgis_raster SCHEMA public VERSION unpackaged;*
> *And then *Trying to do below after a rasterless raster extension I would
> expect to fail with the above notice – this is what
> postgis_extensions_upgrade() would be doing internally
> *ALTER EXTENSION postgis_raster UPDATE TO "3.2.3""*
> This is a fake install, and can be dropped with
> *DROP EXTENSION postgis_raster;*
> but the fact you showed (raster procs from ""2.4.4 r16526"" need upgrade)"
> suggests this is not the case, and you are more likely facing a) or c)
> c) You installed raster in a separate schema from postgis, this again I
> can’t imagine how this is possible, unless you started
> with a postgis install from 2.4.4, using scripts instead of the extension
> system and then you decided to run postgis.sql in one schema and
> rtpostgis.sql in a separate schema.
> And then you proceeded to then convert to an extensions based install.
> In a regular extension install, both postgis.sql and rtpostgis.sql are
> packaged together, so having them somehow end up in different schemas would
> be I think impossible, though I would be impressed if someone could prove
> me wrong.
> Assuming you did an extensionless install, putting raster and postgis in
> separate schemas
> The fix (not tested) would be:
> Figure out which schema you have raster installed in, and make sure you do
> your unpackaged install in the same schema as follows:
> *CREATE EXTENSION postgis_raster SCHEMA <the schema it is installed in
> here> VERSION unpackaged;*
> *ALTER EXTENSION postgis_raster UPDATE;*
> -- this part you need to do because postgis_raster is no longer
> relocatable, and we require both postgis and postgis_raster to reside in
> the same schema.
> -- allow you to move it
> *UPDATE pg_extension SET extrelocatable = true WHERE extname
> ='postgis_raster';*
> -- move it
> *ALTER EXTENSION postgis_raster SET SCHEMA <where the postgis extension is
> installed>;*
> -- at this point many of your raster functions are broken cause they are
> pointing at the old schema, this fixes that mess
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> Behalf Of *Marcelo Marques
> *Sent:* Wednesday, September 7, 2022 5:07 PM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* [postgis-users] ERROR: type "raster" is only a shell
> -- Platform:
> Windows Server 2019
> PostgreSQL 12.12
> Postgis 3.2.3
> *SELECT postgis_full_version();*
> "POSTGIS=""3.2.3 3.2.3"" [EXTENSION] PGSQL=""120""
> GEOS=""3.10.3-CAPI-1.16.1"" PROJ=""7.2.1""
> LIBXML=""2.9.9"" LIBJSON=""0.12"" LIBPROTOBUF=""1.2.1"" WAGYU=""0.5.0
> (Internal)""
> ** NOTE: postgis 3.2.3 and raster 2.4.4 **
> ***-- Upgrade the Postgis Extensions***
> *SELECT postgis_extensions_upgrade();*
> NOTICE: Packaging extension postgis_raster
> CONTEXT: SQL statement
> *"CREATE EXTENSION postgis_raster SCHEMA public VERSION unpackaged;ALTER
> PL/pgSQL function postgis_extensions_upgrade() line 71 at EXECUTE
> SQL state: 42704
> ***QUESTIONS:***
> Why the extension upgrade returns "ERROR: type "raster" is only a shell"
> Is this another bug ???
> Is there any other workaround for this issue besides
> "uninstall_rtpostgis.sql" described below ???
> ***--SOLUTION: ***
> psql
> \c rev
> "Upgrade completed, run SELECT postgis_full_version(); for details"
> NOTICE: Extension postgis_raster is not available or not packagable for
> some reason
> NOTICE: Extension postgis_sfcgal is not available or not packagable for
> some reason
> NOTICE: Extension postgis_topology is not available or not packagable for
> some reason
> NOTICE: Extension postgis_tiger_geocoder is not available or not
> packagable for some reason
> Successfully run. Total query runtime: 144 msec.
> 1 rows affected.
> (Internal)"""
> *CREATE EXTENSION postgis_raster;*
> CREATE EXTENSION
> Query returned successfully in 227 msec.
> GDAL=""GDAL 3.4.3, released 2022/04/22 GDAL_DATA not found""
> (Internal)"" RASTER"
> *SELECT * FROM pg_available_extensions WHERE name LIKE 'postgis%';*
> "name" "default_version" "installed_version" "comment"
> "postgis" "3.2.3" "3.2.3" "PostGIS geometry and geography spatial types
> and functions"
> "postgis_raster" "3.2.3" "3.2.3" "PostGIS raster types and functions"
> DROP EXTENSION
> Query returned successfully in 94 msec.
> I appreciate the assistance to clarify my questions.
> Thanks,
> Marcelo Marques | Principal Product Engineer | Esri - www.esri.com |
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220907/5de801a2/attachment.htm>
