[postgis-users] How to connect to MapServer with an HTTPS protocol
mathias cunault
mathias.cunault at inrap.fr
Sat Sep 24 05:50:26 PDT 2022
Thanks for the answer. Let's try this!
*Mathias Cunault*
*référent SIG / Admin Caviar*
*Inrap Tours - 148 av. Maginot37000 TOURS06 32 05 98 96*
abonnez-vous à la lettre d'information de l'Inrap : http://ww
<http://www.inrap.fr/newsletter.php>w.inrap.fr/newsletter.php
Le lun. 19 sept. 2022 à 19:39, Regina Obe <lr at pcorp.us> a écrit :
> Mathias,
> I think as others have mentioned, to use https you need a SSL certificate.
> If per chance you are using IIS, I use this letsencrypt tool for assigning
> certificates. Works great and automatically renews itself using the built
> in windows scheduler.
> Binaries available as part of the releases on this page --
> https://github.com/win-acme/win-acme/releases
> For IIS on an x64 system, I used the zip marked
> win-acme....x64.pluggable.zip and then run the wacs.exe (make sure to Run
> as Administrator) to install the certs for the sites you need.
> > -----Original Message-----
> > From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On
> > Behalf Of Jeff McKenna
> > Sent: Monday, September 19, 2022 1:10 PM
> > To: postgis-users at lists.osgeo.org
> > Subject: Re: [postgis-users] How to connect to MapServer with an HTTPS
> > protocol
> > Hi Mathias,
> > Since you are serving the WFS service through Windows, you can follow the
> > detailed MS4W steps to serve through HTTPS on that Windows server :
> > https://ms4w.com/README_INSTALL.html#certificates-for-https
> > Once your MS4W instance is serving HTTPS, then you can guide your users
> to
> > follow how to add your WFS HTTPS local layers through this guide:
> > https://mapserver.org/ogc/wxs_secure.html
> > (note: as I maintain both guides, please let me know if there are any
> > additions needed)
> > Thanks!
> > Thank-you for using MS4W.
> > "MS4W: open doors as well as windows"
> > -jeff
> > On 2022-09-19 4:13 a.m., mathias cunault wrote:
> > > Using Mapserver 7.4, I render a WFS that is accessible with some
> > > regular URL like "http://blabla.fr/cg-bin/mapserv.exe?MAP=..
> > > <http://blabla.fr/cg-bin/mapserv.exe?MAP=..>."
> > > A user wants to use this WFS in another application web that needs a
> > > http*S* protocol.
> > > I am not familiar with internet protocols so I don't know where to
> > > start
> > > : is it a Mapserver configuration or a server (windows server R12)
> > > configuration to setup ?
> > > Thanks
> > > /Mathias Cunault/
> > > /r f rent SIG / Admin Caviar
> > > ///Inrap Tours - /148 av. Maginot
> > > 37000 TOURS
> > > 06 32 05 98 96/
> > > abonn//ez-vous la lettre d'information de l'Inrap : http://ww
> > > _______________________________________________
> > > postgis-users mailing list
> > > https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220924/7c632c25/attachment.htm>
