[postgis-users] How to connect to MapServer with an HTTPS protocol
Regina Obe lr at pcorp.us
Mon Sep 19 10:39:00 PDT 2022
Mathias,
I think as others have mentioned, to use https you need a SSL certificate.
If per chance you are using IIS, I use this letsencrypt tool for assigning certificates.  Works great and automatically renews itself using the built in windows scheduler.
Binaries available as part of the releases on this page -- https://github.com/win-acme/win-acme/releases
For IIS on an x64 system, I used the zip marked win-acme....x64.pluggable.zip and then run the wacs.exe (make sure to Run as Administrator)  to install the certs for the sites you need.
> -----Original Message-----
> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On
> Behalf Of Jeff McKenna
> Sent: Monday, September 19, 2022 1:10 PM
> To: postgis-users at lists.osgeo.org
> Subject: Re: [postgis-users] How to connect to MapServer with an HTTPS
> protocol
> Hi Mathias,
> Since you are serving the WFS service through Windows, you can follow the
> detailed MS4W steps to serve through HTTPS on that Windows server :
> https://ms4w.com/README_INSTALL.html#certificates-for-https
> Once your MS4W instance is serving HTTPS, then you can guide your users to
> follow how to add your WFS HTTPS local layers through this guide:
> https://mapserver.org/ogc/wxs_secure.html
> (note: as I maintain both guides, please let me know if there are any
> additions needed)
> Thanks!
> Thank-you for using MS4W.
> "MS4W: open doors as well as windows"
> -jeff
> On 2022-09-19 4:13 a.m., mathias cunault wrote:
> > Using Mapserver 7.4, I render a WFS that is accessible with some
> > regular URL like "http://blabla.fr/cg-bin/mapserv.exe?MAP=..
> > <http://blabla.fr/cg-bin/mapserv.exe?MAP=..>."
> > A user wants to use this WFS in another application web that needs a
> > http*S* protocol.
> > I am not familiar with internet protocols so I don't know where to
> > start
> > : is it a Mapserver configuration or a server (windows server R12)
> > configuration to setup ?
> > Thanks
> > /Mathias Cunault/
> > /r f rent SIG / Admin Caviar
> > ///Inrap Tours - /148 av. Maginot
> > 37000 TOURS
> > 06 32 05 98 96/
> > abonn//ez-vous   la lettre d'information de l'Inrap : http://ww
> > <http://www.inrap.fr/newsletter.php>w.inrap.fr/newsletter.php
> > postgis-users mailing list
> > https://lists.osgeo.org/mailman/listinfo/postgis-users
