[postgis-users] Migration issue
Simon SPDBA Greener simon at spdba.com.au
Wed Sep 28 19:01:05 PDT 2022
Regina,
Thanks for the quick response.
Windows services says there is only one instance running.
I rebooted and reconnected via pgAdmin 4.
Two connections now appear and both return
"PostgreSQL 14.5, compiled by Visual C++ build 1914, 64-bit"
for
SELECT version();
The default/new PostgreSQL 14 connection *allows *create extension
postgis to execute correctly.
And returns this:
SELECT name, setting, category FROM pg_settings WHERE category IN('File
Locations') or name IN('port', 'listen_addresses') ;
"config_file"    "F:/PostgreSQL/14/data/postgresql.conf" "File Locations"
"data_directory"    "F:/PostgreSQL/14/data"    "File Locations"
"external_pid_file"        "File Locations"
"hba_file"    "F:/PostgreSQL/14/data/pg_hba.conf"    "File Locations"
"ident_file"    "F:/PostgreSQL/14/data/pg_ident.conf"    "File Locations"
"listen_addresses"    "*"    "Connections and Authentication /
Connection Settings"
"port"    "5433"    "Connections and Authentication / Connection Settings"
Whereas the bad connection (from the previous 13 database) returns:
"config_file" "E:/Bitnami/WAPPST~1.0-1/POSTGR~1/data/postgresql.conf"
"File Locations"
"data_directory"    "E:/Bitnami/WAPPST~1.0-1/POSTGR~1/data" "File Locations"
"hba_file" "E:/Bitnami/WAPPST~1.0-1/POSTGR~1/data/pg_hba.conf"    "File
Locations"
"ident_file" "E:/Bitnami/WAPPST~1.0-1/POSTGR~1/data/pg_ident.conf"
"File Locations"
"listen_addresses"    "127.0.0.1"    "Connections and Authentication /
"port"    "5432"    "Connections and Authentication / Connection Settings"
I have blown away this connection. I wonder if there is anything else I
need to do?
regards
Simon
On 29/09/2022 11:39 am, Regina Obe wrote:
> Is it possible that maybe you have another PostgreSQL service running
> on the port you think you are running PostgreSQL 14 on.
> The following queries might give you some clues what’s going on.
> IN('File Locations') or name IN('port', 'listen_addresses') ;
> *From:*postgis-users [mailto:postgis-users-bounces at lists.osgeo.org]
> *On Behalf Of *Simon SPDBA Greener
> *Sent:* Wednesday, September 28, 2022 9:00 PM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* [postgis-users] Migration issue
> Windows 10 64bit
> I had a Postgresql 13 instance.
> I exported all the databases within that instance.
> I removed the 13 instance.
> I installed Postgresql 14.
> In PgAdmin 4 I created a new empty database for one of the databases
> exported from the 13 instance.
> I then tried:
> create extension postgis;
> And got this:
> ERROR: could not open extension control file
> "E:/Bitnami/WAPPST~1.0-1/POSTGR~1/share/extension/postgis.control": No
> such file or directory SQL state: 58P01
> I have no idea why it is looking in this this E: folder and not the
> new 14 install directory.
> Any hints as to what I can do?
> regards
> Simon
> Simon Greener
> 39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia
> (m) +61 418 396 391
> (w)www.spdba.com.au  <http://www.spdba.com.au>
> (m)simon at spdba.com.au
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
Simon Greener
(m) +61 418 396 391
(w)www.spdba.com.au
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220929/95be821b/attachment.htm>
