[postgis-users] No extension
Simon SPDBA Greener
simon at spdba.com.au
Wed Sep 28 23:02:35 PDT 2022
Regina,
Thanks for the reply.
> What does
> SELECT *FROM geometry_columns;
> Return. I’m guessing maybe QGIS is complaining about lack of spatial
tables.
It returns a data grid showing all the spatial layers.
> Looked like your PostgreSQL 13 is running on 5432, you could just
disable it. I assume it’s maybe still running in services?
The strange thing was that it had been uninstalled. I removed the rogue
connection in PgAdmin 4 and it fixed the problem.
In my new instance I created a database for each of the backup
databases, execute "create extension postgis" for all of them, then
restored the original data from the backups successfully. I am still
getting this in qGIS logs...
2022-09-29T14:38:36 WARNING No PostGIS support in the database.
2022-09-29T14:38:36 WARNING Database connection was successful, but
the accessible tables could not be determined.
regards
Simon
Simon Greener
39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia
(m) +61 418 396 391
(w)www.spdba.com.au
(m)simon at spdba.com.au
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220929/ba80db7c/attachment.htm>
