[postgis-users] No extension
Simon SPDBA Greener
simon at spdba.com.au
Thu Sep 29 16:46:02 PDT 2022
> You confirmed the port is right the 5433 port (not 5432).
> Just still sounds like it’s trying to connect to the wrong service or
> server still.
> I’d triple check the connection settings, make sure the port and
> IP/hostname is right.
I only have one instance running on my box with multiple databases.
In short I connect to the database DFDB using qGIS with port 5432 and it
worked.
I connect to database GISDB using qGIS with port 5432 and it failed but
then worked with 5433. THANKS!
Any idea why?
Simon
Simon Greener
39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia
(m) +61 418 396 391
(w)www.spdba.com.au
(m)simon at spdba.com.au
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220930/3ebe759c/attachment.htm>
