[postgis-users] No extension
Regina Obe lr at pcorp.us
Thu Sep 29 17:31:54 PDT 2022
When you use the PostgreSQL installer on windows,
If you have a PostgreSQL instance running already on Port 5432, it defaults
the port to the next available increment port.
So my guess is you had your bitnami running on Port 5432, it detected that,
so then installed on Port 5433.
So your old would have 5432, your new PostgreSQL 14 would be 5433.
That's why I mentioned, if you wanted it to run on default PostgreSQL 5432,
you can do the
Run the sql:
ALTER SYSTEM Set port = '5432';
Then restart the service.
And that registry change I mentioned.
Open regedit.exe
HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Services\postgresql-x64-14\
Key: Port
The registry change you do so if you install other extensions such as
postgis or pgAgent that need to connect to the database, they read the port
number from the registry and default to that. I think pgAdmin4 also when you
first setup reads port from registry.
> -----Original Message-----
> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On
Behalf
> Of Simon SPDBA Greener
> Sent: Thursday, September 29, 2022 7:50 PM
> To: postgis-users at lists.osgeo.org
> Subject: Re: [postgis-users] No extension
> Hold that thought.
> Port 5432 didn't work on DFDB as I thought it did.
> Port 5433 works.
> Has the default port changed with database installs?
> Simon
> > Simon Greener
> > 39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia
> > (m) +61 418 396 391
> > (w)www.spdba.com.au
> > (m)simon at spdba.com.au
> > postgis-users mailing list
> > https://lists.osgeo.org/mailman/listinfo/postgis-users
> Simon Greener
> (m) +61 418 396 391
> (w) www.spdba.com.au
> (m) simon at spdba.com.au
