[postgis-users] No extension
Simon SPDBA Greener
simon at spdba.com.au
Thu Sep 29 20:08:27 PDT 2022
I decided to switch the port back to 5432 following your recipe (because
I have many apps that access postgresql).
I can connect using qGIS/pgAdmin 4 etc but when I try to connect using
GeoServer I get this:
at java.base/java.lang.Thread.run(Thread.java:831)
Caused by: java.lang.RuntimeException: Unable to obtain connection:
ERROR: function postgis_lib_version() does not exist
Hint: No function matches the given name and argument types. You
might need to add explicit type casts.
Position: 8
at
org.geotools.jdbc.JDBCDataStore.createConnection(JDBCDataStore.java:2132)
Running the function in pgAdmin 4 returns:
select postgis_lib_version();
"postgis_lib_version"
"3.2.3"
Any ideas?
All other apps work correctly, only GeoServer is returning this error.
regards
Simon
On 30/09/2022 11:39 am, Simon SPDBA Greener wrote:
> The old postgresql 13 was running on 5432.
> I thought I had shut it down before running the 14 installer.
> No matter, your suggestion about 5433 was the key I needed to open the
> door.
> Thanks for all your patience and help: greatly appreciated.
> regards
> Simon
> On 30/09/2022 10:31 am, Regina Obe wrote:
>> When you use the PostgreSQL installer on windows,
>> If you have a PostgreSQL instance running already on Port 5432, it
>> defaults
>> the port to the next available increment port.
>> So my guess is you had your bitnami running on Port 5432, it detected
>> that,
>> so then installed on Port 5433.
>> So your old would have 5432, your new PostgreSQL 14 would be 5433.
>> That's why I mentioned, if you wanted it to run on default PostgreSQL
>> 5432,
>> you can do the
>> Run the sql:
>> ALTER SYSTEM Set port = '5432';
>> Then restart the service.
>> And that registry change I mentioned.
>> Open regedit.exe
>> HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Services\postgresql-x64-14\
>> Key: Port
>> The registry change you do so if you install other extensions such as
>> postgis or pgAgent that need to connect to the database, they read
>> the port
>> number from the registry and default to that. I think pgAdmin4 also
>> when you
>> first setup reads port from registry.
>>> -----Original Message-----
>>> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On
>> Behalf
>>> Of Simon SPDBA Greener
>>> Sent: Thursday, September 29, 2022 7:50 PM
>>> To: postgis-users at lists.osgeo.org
>>> Subject: Re: [postgis-users] No extension
>>> Hold that thought.
>>> Port 5432 didn't work on DFDB as I thought it did.
>>> Port 5433 works.
>>> Has the default port changed with database installs?
>>> Simon
>>>> Simon Greener
>>>> 39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia
>>>> (m) +61 418 396 391
>>>> (w)www.spdba.com.au
>>>> (m)simon at spdba.com.au
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
>>> Simon Greener
>>> (m) +61 418 396 391
>>> (w) www.spdba.com.au
>>> (m) simon at spdba.com.au
Simon Greener
(m) +61 418 396 391
