[postgis-users] Library function 'pgis_geometry_union_finalfn' was deprecated in PostGIS 3.3.0
Giuseppe Naponiello
beppenapo at gmail.com
Fri Sep 30 00:25:38 PDT 2022
this is my postgis version:
POSTGIS="3.3.1 3786b21" [EXTENSION] PGSQL="130"
GEOS="3.9.0-CAPI-1.16.2" PROJ="7.2.1" GDAL="GDAL 3.2.2, released
2021/03/05" LIBXML="2.9.10" LIBJSON="0.15" LIBPROTOBUF="1.3.3"
WAGYU="0.5.0 (Internal)" (core procs from "3.1.4 ded6c34" need upgrade)
RASTER (raster lib from "2.4.9 r0" need upgrade) [UNPACKAGED!] (raster
procs from "2.4.9" need upgrade)
(1 riga)
I need to centered a leaflet map on centroid of 5 merged polygons, my
query is:
select st_X(st_centroid(st_union(st_transform(ST_SetSRID(geom,3857),
4326)))) as lat,
st_Y(st_centroid(st_union(st_transform(ST_SetSRID(geom,3857), 4326))))
as lon from comuni;
this query has always worked well, until some system update (I use
debian stable and postgresql 13), so now I have:
ERROR: A stored procedure tried to use deprecated C function
DETAIL: Library function 'pgis_geometry_union_finalfn' was deprecated
in PostGIS 3.3.0
HINT: Consider running: SELECT postgis_extensions_upgrade()
and if I run this select I have:
ERROR: extension "postgis" has no update path from version "3.1.4" to
version "2.4.9"
If I use ST_MemUnion (instead of st_union) works well but I don't think
is the correct solution.
Any tips?
thanx
-beppe-
