[postgis-users] No extension
Simon Greener simon at spdba.com.au
Fri Sep 30 01:55:31 PDT 2022
Yes, it is uninstalled.
⁣39 Cliff View Drive
Allens Rivulet Tas 7150
(W) 0418 396 391​
On 30 Sep 2022, 18:24, at 18:24, Alexandre Neto <senhor.neto at gmail.com> wrote:
>Did you uninstall PostgreSQL 13?
>A sexta, 30/09/2022, 04:08, Simon SPDBA Greener <simon at spdba.com.au>
>escreveu:
>> I decided to switch the port back to 5432 following your recipe
>(because
>> I have many apps that access postgresql).
>> I can connect using qGIS/pgAdmin 4 etc but when I try to connect
>using
>> GeoServer I get this:
>>     at java.base/java.lang.Thread.run(Thread.java:831)
>> Caused by: java.lang.RuntimeException: Unable to obtain connection:
>> ERROR: function postgis_lib_version() does not exist
>>    Hint: No function matches the given name and argument types. You
>> might need to add explicit type casts.
>>    Position: 8
>>      at
>org.geotools.jdbc.JDBCDataStore.createConnection(JDBCDataStore.java:2132)
>> Running the function in pgAdmin 4 returns:
>> select postgis_lib_version();
>> "postgis_lib_version"
>> "3.2.3"
>> Any ideas?
>> All other apps work correctly, only GeoServer is returning this
>error.
>> regards
>> Simon
>> On 30/09/2022 11:39 am, Simon SPDBA Greener wrote:
>> > The old postgresql 13 was running on 5432.
>> > I thought I had shut it down before running the 14 installer.
>> > No matter, your suggestion about 5433 was the key I needed to open
>the
>> > door.
>> > Thanks for all your patience and help: greatly appreciated.
>> > regards
>> > Simon
>> > On 30/09/2022 10:31 am, Regina Obe wrote:
>> >> When you use the PostgreSQL installer on windows,
>> >> If you have a PostgreSQL instance running already on Port 5432, it
>> >> defaults
>> >> the port to the next available increment port.
>> >> So my guess is you had your bitnami running on Port 5432, it
>detected
>> >> that,
>> >> so then installed on Port 5433.
>> >> So your old would have 5432, your new PostgreSQL 14 would be 5433.
>> >> That's why I mentioned, if you wanted it to run on default
>PostgreSQL
>> >> 5432,
>> >> you can do the
>> >> Run the sql:
>> >> ALTER SYSTEM Set port = '5432';
>> >> Then restart the service.
>> >> And that registry change I mentioned.
>> >> Open regedit.exe
>> >> HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Services\postgresql-x64-14\
>> >> Key: Port
>> >> The registry change you do so if you install other extensions such
>as
>> >> postgis or pgAgent that need to connect to the database, they read
>> >> the port
>> >> number from the registry and default to that. I think pgAdmin4
>also
>> >> when you
>> >> first setup reads port from registry.
>> >>> -----Original Message-----
>> >>> From: postgis-users
>[mailto:postgis-users-bounces at lists.osgeo.org] On
>> >> Behalf
>> >>> Of Simon SPDBA Greener
>> >>> Sent: Thursday, September 29, 2022 7:50 PM
>> >>> To: postgis-users at lists.osgeo.org
>> >>> Subject: Re: [postgis-users] No extension
>> >>> Hold that thought.
>> >>> Port 5432 didn't work on DFDB as I thought it did.
>> >>> Port 5433 works.
>> >>> Has the default port changed with database installs?
>> >>> Simon
>> >>>> Simon Greener
>> >>>> 39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia
>> >>>> (m) +61 418 396 391
>> >>>> (w)www.spdba.com.au
>> >>>> (m)simon at spdba.com.au
>> >>>> _______________________________________________
>> >>>> postgis-users mailing list
>> >>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
>> >>> Simon Greener
>> >>> (m) +61 418 396 391
>> >>> (w) www.spdba.com.au
>> >>> (m) simon at spdba.com.au
>> Simon Greener
>> (m) +61 418 396 391
