[postgis-users] Ynt: PostGIS 3.4.0rc1 released
Devrim Gündüz
devrim at gunduz.org
Tue Aug 8 04:26:01 PDT 2023
On Tue, 2023-08-08 at 11:23 +0000, Bekir Niyaz wrote:
> Im trying to install postgis33_15-3.3.3-1.rhel8.x86_64 on Rocky Linux
> 8 but getting these errors. Is this issue caused packaging errors or
> whatelse.
> dnf -y install postgis33_15.x86_64
> Last metadata expiration check: 0:00:28 ago on Tue 08 Aug 2023
> 02:12:52 PM +03.
> Error:
> Problem: package postgis33_15-3.3.3-1.rhel8.x86_64 requires gdal35-
> libs >= 3.5.3, but none of the providers can be installed
> - cannot install the best candidate for the job
> - nothing provides libqhull_r.so.7()(64bit) needed by gdal35-libs-
> 3.5.3-4.rhel8.x86_64
> (try to add '--skip-broken' to skip uninstallable packages or '--
> nobest' to use not only best candidate packages)
Run:
crb enable
Regards,
Devrim Gündüz
Open Source Solution Architect, PostgreSQL Major Contributor
Twitter: @DevrimGunduz , @DevrimGunduzTR
