[postgis-users] Ynt: Ynt: PostGIS 3.4.0rc1 released
Bekir Niyaz bagafoot at hotmail.com
Tue Aug 8 04:46:09 PDT 2023
Thanks a lot Devrim Hocam 🙂
that works.
Saygılarımla
Regards
Gönderen: Devrim Gündüz <devrim at gunduz.org> adına postgis-users <postgis-users-bounces at lists.osgeo.org>
Gönderildi: 8 Ağustos 2023 Salı 14:26
Kime: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Konu: Re: [postgis-users] Ynt: PostGIS 3.4.0rc1 released
On Tue, 2023-08-08 at 11:23 +0000, Bekir Niyaz wrote:
> Im trying to install postgis33_15-3.3.3-1.rhel8.x86_64 on Rocky Linux
> 8 but getting these errors. Is this issue caused packaging errors or
> whatelse.
> dnf -y install postgis33_15.x86_64
> Last metadata expiration check: 0:00:28 ago on Tue 08 Aug 2023
> 02:12:52 PM +03.
> Error:
>  Problem: package postgis33_15-3.3.3-1.rhel8.x86_64 requires gdal35-
> libs >= 3.5.3, but none of the providers can be installed
>   - cannot install the best candidate for the job
>   - nothing provides libqhull_r.so.7()(64bit) needed by gdal35-libs-
> 3.5.3-4.rhel8.x86_64
> (try to add '--skip-broken' to skip uninstallable packages or '--
> nobest' to use not only best candidate packages)
Run:
crb enable
Regards,
Devrim Gündüz
Open Source Solution Architect, PostgreSQL Major Contributor
Twitter: @DevrimGunduz , @DevrimGunduzTR
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230808/0baceaaa/attachment.htm>
