[postgis-users] Size of geometry issue
Regina Obe
lr at pcorp.us
Wed Aug 9 07:02:12 PDT 2023
Your version should have those functions available since these functions came in PostGIS 3.1 and your GEOS is newer than 3.9
https://postgis.net/docs/manual-3.2/ST_Union.html
Do you get an error when you run ST_Union with a gridsize? If so maybe your GEOS might be newer but you compiled with a lower version of GEOS.
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Shaozhong SHI
Sent: Wednesday, August 9, 2023 1:40 AM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] Size of geometry issue
On Wed, 9 Aug 2023 at 04:30, Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
What is output of your
SELECT postgis_full_version();
It is:
POSTGIS="3.1.9 95a641b" [EXTENSION] PGSQL="130" GEOS="3.10.3-CAPI-1.16.1" SFCGAL="1.3.1" PROJ="7.2.1" LIBXML="2.9.1" LIBJSON="0.11" (core procs from "3.1.4 ded6c34" need upgrade) (sfcgal procs from "3.1.4 ded6c34" need upgrade)
Regards,
David
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org <mailto:postgis-users-bounces at lists.osgeo.org> ] On Behalf Of Shaozhong SHI
Sent: Tuesday, August 8, 2023 6:49 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org> >
Hi, Regina,
It did not work.
Regards, David
On Tuesday, 8 August 2023, Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
Are you running GEOS > 3.9.
If so maybe ST_Union with a gridsize might work better for you needs over ST_Collect
https://postgis.net/docs/ST_Union.html
There are also a number of precision reduction functions
https://postgis.net/docs/ST_SimplifyPreserveTopology.html
https://postgis.net/docs/ST_SnapToGrid.html
come to mind
Sent: Tuesday, August 8, 2023 5:46 PM
Subject: [postgis-users] Size of geometry issue
St_collect is used and size issue may cause the problem.
If just their relationship needs to be depicted, how can the size of geometry be reduced?
Regards,
David
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230809/8d116c51/attachment.htm>
