[postgis-users] Size of geometry issue
Shaozhong SHI
shishaozhong at gmail.com
Wed Aug 9 10:21:25 PDT 2023
Hi Regina,
I think I found the answer. It is not because it is too big. It is it
returned nothing to be inserted.
The message is rather miss-leading.
I put on test run. Hopefully I get confirmation tomorrow.
Regards, David
On Wednesday, 9 August 2023, Regina Obe <lr at pcorp.us> wrote:
> Your version should have those functions available since these functions
> came in PostGIS 3.1 and your GEOS is newer than 3.9
> https://postgis.net/docs/manual-3.2/ST_Union.html
> Do you get an error when you run ST_Union with a gridsize? If so maybe
> your GEOS might be newer but you compiled with a lower version of GEOS.
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> Behalf Of *Shaozhong SHI
> *Sent:* Wednesday, August 9, 2023 1:40 AM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* Re: [postgis-users] Size of geometry issue
> On Wed, 9 Aug 2023 at 04:30, Regina Obe <lr at pcorp.us> wrote:
> What is output of your
> SELECT postgis_full_version();
> It is:
> POSTGIS="3.1.9 95a641b" [EXTENSION] PGSQL="130" GEOS="3.10.3-CAPI-1.16.1"
> SFCGAL="1.3.1" PROJ="7.2.1" LIBXML="2.9.1" LIBJSON="0.11" (core procs from
> "3.1.4 ded6c34" need upgrade) (sfcgal procs from "3.1.4 ded6c34" need
> upgrade)
> Regards,
> David
> *Sent:* Tuesday, August 8, 2023 6:49 PM
> Hi, Regina,
> It did not work.
> Regards, David
> On Tuesday, 8 August 2023, Regina Obe <lr at pcorp.us> wrote:
> Are you running GEOS > 3.9.
> If so maybe ST_Union with a gridsize might work better for you needs over
> ST_Collect
> https://postgis.net/docs/ST_Union.html
> There are also a number of precision reduction functions
> https://postgis.net/docs/ST_SimplifyPreserveTopology.html
> https://postgis.net/docs/ST_SnapToGrid.html
> come to mind
> *Sent:* Tuesday, August 8, 2023 5:46 PM
> *Subject:* [postgis-users] Size of geometry issue
> St_collect is used and size issue may cause the problem.
> If just their relationship needs to be depicted, how can the size of
> geometry be reduced?
> Regards,
> David
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230809/f6306570/attachment.htm>
