[postgis-users] PostGIS 3.4 on PG 16 observations
Gandalf the Gray
pjduplooy.gis at gmail.com
Mon Aug 14 07:12:08 PDT 2023
Yes, I mean CREATE EXTENSION
On Mon, Aug 14, 2023 at 4:09 PM Regina Obe <lr at pcorp.us> wrote:
> Command line. You mean CREATE EXTENSION? Just making sure. I see it in
> my extension drop down but could be a refresh issue or something I’m
> missing cause I’m using a slightly earlier build.
> H3_postgis ah yes I get the same error. I’ll let you know once fixed.
> Thanks,
> Regina
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> Behalf Of *Gandalf the Gray
> *Sent:* Monday, August 14, 2023 6:57 AM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* [postgis-users] PostGIS 3.4 on PG 16 observations
> Hi
> I have made the following observations regarding PostGIS 3.4 on PG 16
> using the archives on buildbot for Winnie.
> PostGIS proper works perfectly.
> PgRouting does not appear in the list of extensions while using PGAdmin,
> although it is installable using the command line.
> H3_postgis is not installable at all, and gives me the following error:
> could not access file "h3_postgis": No such file or directory
> H3 is however , installable.
> Regards
> Pieter
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230814/d5044c2b/attachment.htm>
