[postgis-users] PostGIS 3.4 on PG 16 observations
Regina Obe lr at pcorp.us
Mon Aug 14 07:33:11 PDT 2023
The h3_postgis issue should be fixed now.  Note that it is now a tagged build instead of using the main repo.
https://winnie.postgis.net/download/windows/pg16/buildbot/extras/h3-pg_pg16-binaries-v4.1.3w64.zip
Thanks for testing,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Gandalf the Gray
Sent: Monday, August 14, 2023 10:12 AM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] PostGIS 3.4 on PG 16 observations
Yes, I mean CREATE EXTENSION
On Mon, Aug 14, 2023 at 4:09 PM Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
Command line.  You mean CREATE EXTENSION?  Just making sure.  I see it in my extension drop down but could be a refresh issue or something I’m missing cause I’m using a slightly earlier build.
H3_postgis ah yes I get the same error.  I’ll let you know once fixed.
Thanks,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org <mailto:postgis-users-bounces at lists.osgeo.org> ] On Behalf Of Gandalf the Gray
Sent: Monday, August 14, 2023 6:57 AM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org> >
Subject: [postgis-users] PostGIS 3.4 on PG 16 observations
Hi
I have made the following observations regarding PostGIS 3.4 on PG 16 using the archives on buildbot for Winnie.
PostGIS proper works perfectly.
PgRouting does not appear in the list of extensions while using PGAdmin, although it is installable using the command line.
H3_postgis is not installable at all, and gives me the following error:
could not access file "h3_postgis": No such file or directory
H3 is however , installable.
Regards
Pieter
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230814/b3051474/attachment.htm>
