[postgis-users] PostGIS crash on ST_ConcaveHull
耳辰
erchen.cz at alibaba-inc.com
Fri Aug 18 06:03:41 PDT 2023
Hi guys,
I met a postgis crash when tried to use ST_ConvaveHull function with a multipoint, in postgis 3.3.2 and Geos 3.11.2 :
select ST_ConcaveHull('MULTIPOINT ((113.56577197798602 22.80081530883069),(113.565723279387 22.800815316487014),(113.56571548761124 22.80081531771092),(113.56571548780202 22.800815317674463),(113.56577197817877 22.8008153088047),(113.56577197798602 22.80081530883069))', 0.75);
The crash stack are listed:
#0 0x0000ffff84e02210 in geos::triangulate::tri::Tri::getIndex(geos::triangulate::tri::Tri const*) const () from /home/erchen.cz/pgsql15/lib/libgeos.so.3.11.2
#1 0x0000ffff84ce74c0 in geos::algorithm::hull::HullTriangulation::nextBorderTri(geos::algorithm::hull::HullTri*) ()
#2 0x0000ffff84ce7698 in geos::algorithm::hull::HullTriangulation::traceBoundary(geos::triangulate::tri::TriList<geos::algorithm::hull::HullTri>&) ()
#3 0x0000ffff84ce79d4 in geos::algorithm::hull::HullTriangulation::traceBoundaryPolygon(geos::triangulate::tri::TriList<geos::algorithm::hull::HullTri>&, geos::geom::GeometryFactory const*) ()
#4 0x0000ffff84ce1f28 in geos::algorithm::hull::ConcaveHull::toGeometry(geos::triangulate::tri::TriList<geos::algorithm::hull::HullTri>&, geos::geom::GeometryFactory const*) () from /home/erchen.cz/pgsql15/lib/libgeos.so.3.11.2
#5 0x0000ffff84ce29d4 in geos::algorithm::hull::ConcaveHull::getHull() ()
#6 0x0000ffff8e54818c in GEOSConcaveHull_r ()
from /home/erchen.cz/pgsql15/lib/libgeos_c.so.1
It seemed that geos was failed to triangulate the multipoint and then crashed … Is this a bug of geos?
Any comment is welcomed.
Regards,
Zhen
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230818/7e4f4440/attachment.htm>
