[postgis-users] raster2pgsql gives me segmentation fault
Regina Obe
lr at pcorp.us
Mon Dec 4 09:40:13 PST 2023
What does SELECT version() return?
Also have you tried it with in-db. (without the -R switch). Could be some sort of permission issue. If it still breaks with in-db, that would rule out out-db as the culprit.
I know the out-db logic we have is still not that popular so much less tested than in-db. If we can isolate it down a bit more to being an out-db or permission issue that would help.
Sent: Monday, December 4, 2023 10:08 AM
To: Regina Obe <lr at pcorp.us>
Cc: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] raster2pgsql gives me segmentation fault
Thank you Regina.
I'm using "POSTGIS="3.1.1 aaf4c79" [EXTENSION] PGSQL="130" GEOS="3.9.4-CAPI-1.14.4" PROJ="7.2.1" GDAL="GDAL 3.2.2, released 2021/03/05" LIBXML="2.9.10" LIBJSON="0.15" LIBPROTOBUF="1.4.1" WAGYU="0.5.0 (Internal)" TOPOLOGY RASTER"
___________________
Andrea Borruso
website: https://medium.com/tantotanto
38° 7' 48" N, 13° 21' 9" E, EPSG:4326
___________________
"cercare e saper riconoscere chi e cosa,
in mezzo all’inferno, non è inferno,
e farlo durare, e dargli spazio"
Italo Calvino
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20231204/2a2e2689/attachment.htm>
