[postgis-users] out db: not able to query the raster
andy aborruso at gmail.com
Mon Dec 4 14:23:31 PST 2023
if I run "SELECT (ST_BandMetaData(rast)).* FROM rasters_outdb LIMIT 1;", in
the field path I have "/directory_docker/ou_s6_01_01_stack.tif"
If I run "ls -l /directory_docker/ou_s6_01_01_stack.tif" I have
-rwxr--r-- 1 1000 1000 2100227 Dec  4 08:32
But when I run "SELECT ST_Value(rast, 1, 1) FROM rasters_outdb;" I get
ERROR:  rt_band_load_offline_data: Cannot open offline raster:
Why is it offline? It's there.
I'm using postgis/postgis:16-master
I have created the sql file to load it in postgres, running
raster2pgsql -I -C -M -F -t auto -R /directory_docker/ou_s6_01_01_stack.tif
public.rasters_outdb
How to read the pixel values using a PG SQL query?
Thank you
___________________
Andrea Borruso
website: https://medium.com/tantotanto
38° 7' 48" N, 13° 21' 9" E, EPSG:4326
___________________
"cercare e saper riconoscere chi e cosa,
 in mezzo all’inferno, non è inferno,
e farlo durare, e dargli spazio"
Italo Calvino
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20231204/3c765ff5/attachment.htm>
