[postgis-users] out db: not able to query the raster
Regina Obe
lr at pcorp.us
Wed Dec 6 15:04:20 PST 2023
Yah the data directory is less likely to have screwed up permissions that the postgres account can’t access. So I would go with Jorge’s idea.
That said I would think that having permission with r r r should do the trick and the fact you can get a directory listing suggests the postgres process can at least read the list of files.
The only thing I can think of is maybe something is locking those files in some write mode preventing any other process from reading. I’m assuming you are done with loading so shouldn’t be that.
To rule out postgis raster is at fault, maybe try restarting the service and do that pg_stat_file check again immediately after restarting.
Regarding your question about “Why is it offline? It's there.”
It’s offline because it’s not in your database. Out-db / offline are equivalent terminology in postgis raster. We should probably change that terminology to out-db cause offline means not reachable in other contexts and just confusing. I think calling it out-db is a lot clearer.
From: postgis-users <postgis-users-bounces at lists.osgeo.org> On Behalf Of Jorge Gustavo Rocha via postgis-users
Sent: Wednesday, December 6, 2023 5:25 PM
To: postgis-users at lists.osgeo.org
Cc: Jorge Gustavo Rocha <jgr at di.uminho.pt>
Subject: Re: [postgis-users] out db: not able to query the raster
Hi Andrea,
I always put the raster somewhere below Postgresql data_directory.
psql
show data_directory;
I hope it helps.
Saluti,
Jorge
On 04/12/23 22:23, andy via postgis-users wrote:
if I run "SELECT (ST_BandMetaData(rast)).* FROM rasters_outdb LIMIT 1;", in the field path I have "/directory_docker/ou_s6_01_01_stack.tif"
If I run "ls -l /directory_docker/ou_s6_01_01_stack.tif" I have
-rwxr--r-- 1 1000 1000 2100227 Dec 4 08:32 /directory_docker/ou_s6_01_01_stack.tif
But when I run "SELECT ST_Value(rast, 1, 1) FROM rasters_outdb;" I get
ERROR: rt_band_load_offline_data: Cannot open offline raster: /directory_docker/ou_s6_01_01_stack.tif
I'm using postgis/postgis:16-master
I have created the sql file to load it in postgres, running
raster2pgsql -I -C -M -F -t auto -R /directory_docker/ou_s6_01_01_stack.tif public.rasters_outdb
How to read the pixel values using a PG SQL query?
Thank you
___________________
Andrea Borruso
website: https://medium.com/tantotanto
38° 7' 48" N, 13° 21' 9" E, EPSG:4326
___________________
"cercare e saper riconoscere chi e cosa,
in mezzo all’inferno, non è inferno,
e farlo durare, e dargli spazio"
Italo Calvino
postgis-users mailing list
postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20231206/b6bff417/attachment.htm>
