[postgis-users] Upgrade 12->13 stuck due to postgis / raster issue
Roxanne Reid-Bennett rox at tara-lu.com
Mon Jan 23 18:29:26 PST 2023
Jim,
I did a search on this phrase:
 raster procs from "2.5.2 r17328" need upgrade
I found a post from Regina from 2020 moving from 2.5.2 to 3. It might illumine a bit.
https://lists.osgeo.org/pipermail/postgis-users/2020-May/044225.html
And this one for someone who had 100% control of their PG hardware from last fall.
https://groups.google.com/g/postgis-users/c/26iNuhXFHgg
And this one from the AWS forums
https://repost.aws/questions/QUEk9HG5x3Qq6sEB3lVmynUw/upgrade-from-postgres-12-7-r-1-to-13-3-r-1-stuck
which references this:
https://stackoverflow.com/questions/42634626/postgresql-upgrade-on-amazon-rds-blocked-by-postgis-version
which uses
ALTER EXTENSION postgis UPDATE;
The observation in the last post about waiting overnight and things "magically being fixed", I saw during our dry run, not the production run, but definitely during the dry run.  Their observation about rebooting the PG server between upgrades isn't totally "off" either.
Posting in the AWS Forums might get some help from inside Amazon.
Or, if you have any level of support from AWS that would allow you get someone to "poke/prod" on disk, you might get a fix.
Migrating the data is "of course" a last resort, but at least possible.
Given my lack of knowledge of the upgrade steps, I've done what I can.  Good luck.
Roxanne
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230124/ef04a1f5/attachment.htm>
