[postgis-users] Problem compiling postgis
Pankaj K Garg garg at zeemaps.com
Fri Jun 2 09:48:07 PDT 2023
I cannot compile Postgis 3.3.3 (or 3.2.3) on Mac OS Ventura 13.4.
I installed abseil using brew. Abseil mandates the use of at least C++14. PostGIS is trying the build flatgeobuf with C++11.
Will appreciate any help or pointers.
Thanks.
Pankaj
---- Making all in postgis
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ../deps/flatgeobuf all
gcc -std=c++11 -x c++ -I../../liblwgeom -I../../liblwgeom -I./include  -I/usr/local/Cellar/geos/3.11.2/include -I/usr/local/Cellar/proj/9.2.0_1/include -I/usr/local/Cellar/libtiff/4.5.0/include -I/usr/local/Cellar/zstd/1.5.5/include -I/usr/local/Cellar/jpeg-turbo/2.1.5.1/include  -I/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include  -I/usr/local/Cellar/json-c/0.16/include -I/usr/local/Cellar/json-c/0.16/include/json-c -I/usr/local/Cellar/pcre2/10.42/include -DNDEBUG    -fno-common -DPIC -c -o flatgeobuf_c.o flatgeobuf_c.cpp
In file included from flatgeobuf_c.cpp:26:
In file included from ./feature_generated.h:7:
In file included from ./include/flatbuffers/flatbuffers.h:22:
In file included from ./include/flatbuffers/array.h:20:
In file included from ./include/flatbuffers/base.h:237:
In file included from /usr/local/include/absl/strings/string_view.h:39:
In file included from /usr/local/include/absl/base/attributes.h:37:
In file included from /usr/local/include/absl/base/config.h:86:
/usr/local/include/absl/base/policy_checks.h:79:2: error: "C++ versions less than C++14 are not supported."
#error "C++ versions less than C++14 are not supported."
1 error generated.
make[2]: *** [flatgeobuf_c.o] Error 1
make[1]: *** [../deps/flatgeobuf/libflatgeobuf.la] Error 2
make: *** [all] Error 1
9:42 postgis-3.3.3 %
ZeeMaps        http://www.zeemaps.com
21060 Homestead Road, Suite 150        support at zeemaps.com
Cupertino, CA 95014        408 914-2955
Like us on Facebook: http://www.facebook.com/zeemaps               Follow us on Twitter: http://twitter.com/zeemaps
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230602/720b63cb/attachment.htm>
