[postgis-users] [postgis-devel] Problem compiling postgis
Regina Obe
lr at pcorp.us
Fri Jun 2 12:47:23 PDT 2023
I think Bjorn was concerned it was too big of an update to push into a stable release,
Though I guess if it's preventing people from building, maybe we need to or at least a partial update.
I'm not sure we should bother with 3.2 though as it seems to be an issue that is affecting newer OS and such people probably won't be bothering with PostGIS 3.2.
Added back the users list and Pankaj.
Thanks,
Regina
> -----Original Message-----
> From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf
> Of Paul Ramsey
> Sent: Friday, June 2, 2023 3:05 PM
> To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
> Cc: Björn Harrtell <bjorn.harrtell at gmail.com>
> Subject: Re: [postgis-devel] [postgis-users] Problem compiling postgis
> Ah, that explains failures in 3.2/3.3… seems like a back port is also required.
> P
> > On Jun 2, 2023, at 12:03 PM, Regina Obe <lr at pcorp.us> wrote:
> > I think he pushed the latest flatgeobuf in 3.4.0
> > Is it this one - https://github.com/postgis/postgis/pull/726
> > https://trac.osgeo.org/postgis/ticket/5368
> >> Behalf Of Paul Ramsey
> >> Sent: Friday, June 2, 2023 2:54 PM
> >> To: Even Rouault <even.rouault at spatialys.com>; Björn Harrtell
> >> Cc: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
> >> postgis
> >> Am I reading this right, we have flatgeobuf vendored in? Bjorn could
> >> you update our copy to what you think it a good state?
> >> On Fri, Jun 2, 2023 at 10:07 AM Even Rouault
> >> wrote:
> >>> cf MapServer fix for similar issue:
> >>> https://github.com/MapServer/MapServer/pull/6833 (the issue was
> >>> fixed in upstream flatbuffers)
> >>> Le 02/06/2023 à 19:00, Paul Ramsey a écrit :
> >>> Wait, we now have an implicit abseil dependency from flatgeobuf?
> >>> On Jun 2, 2023, at 9:48 AM, Pankaj K Garg <garg at zeemaps.com> wrote:
> >>> I cannot compile Postgis 3.3.3 (or 3.2.3) on Mac OS Ventura 13.4.
> >>> I installed abseil using brew. Abseil mandates the use of at least C++14.
> >> PostGIS is trying the build flatgeobuf with C++11.
> >>> Will appreciate any help or pointers.
> >>> Thanks.
> >>> Pankaj
> >>> ---- Making all in postgis
> >>> /Applications/Xcode.app/Contents/Developer/usr/bin/make -C
> >> ../deps/flatgeobuf all
> >>> gcc -std=c++11 -x c++ -I../../liblwgeom -I../../liblwgeom
> >>> -I./include -
> >> I/usr/local/Cellar/geos/3.11.2/include
> >> -I/usr/local/Cellar/proj/9.2.0_1/include
> >> -I/usr/local/Cellar/libtiff/4.5.0/include
> >> -I/usr/local/Cellar/zstd/1.5.5/include -
> >> I/usr/local/Cellar/jpeg-turbo/2.1.5.1/include -
> I/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform
> >> / Developer/SDKs/MacOSX.sdk/usr/include -I/usr/local/Cellar/json-
> >> c/0.16/include -I/usr/local/Cellar/json-c/0.16/include/json-c -
> >> I/usr/local/Cellar/pcre2/10.42/include -DNDEBUG -fno-common -DPIC -c
> -o
> >> flatgeobuf_c.o flatgeobuf_c.cpp
> >>> In file included from flatgeobuf_c.cpp:26:
> >>> In file included from ./feature_generated.h:7:
> >>> In file included from ./include/flatbuffers/flatbuffers.h:22:
> >>> In file included from ./include/flatbuffers/array.h:20:
> >>> In file included from ./include/flatbuffers/base.h:237:
> >>> In file included from /usr/local/include/absl/strings/string_view.h:39:
> >>> In file included from /usr/local/include/absl/base/attributes.h:37:
> >>> In file included from /usr/local/include/absl/base/config.h:86:
> >>> /usr/local/include/absl/base/policy_checks.h:79:2: error: "C++
> >>> versions less
> >> than C++14 are not supported."
> >>> #error "C++ versions less than C++14 are not supported."
> >>> 1 error generated.
> >>> make[2]: *** [flatgeobuf_c.o] Error 1
> >>> make[1]: *** [../deps/flatgeobuf/libflatgeobuf.la] Error 2
> >>> make: *** [all] Error 1
> >>> 9:42 postgis-3.3.3 %
> >>> ________________________________
> >>> ZeeMaps
> >> http://www.zeemaps.com
> >>> 21060 Homestead Road, Suite 150
> >> support at zeemaps.com
> >>> Cupertino, CA 95014
> >> 408 914-2955
> >>> Like us on Facebook: http://www.facebook.com/zeemaps Follow
> us
> >> on Twitter: http://twitter.com/zeemaps
> >>> _______________________________________________
> >>> postgis-users mailing list
> >>> postgis-users at lists.osgeo.org
> >>> https://lists.osgeo.org/mailman/listinfo/postgis-users
> >>> postgis-devel mailing list
> >>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
> >>> http://www.spatialys.com
> >>> My software is free, but my time generally not.
