[postgis-users] ERROR: transform: Point outside of projection domain (2050)
pham lan
phamlankt at gmail.com
Mon Mar 27 15:29:52 PDT 2023
Yes, you are right. This seems to be a mess. I will clean up the target
server to have similar config like the original one and run the
pg_basebackup again. Unfortunately, I am not allowed to touch the original
server, but creating a backup of that, then pg_ upgrade from that backup.
But if proj7.2 and 8.2.1 are different, i might get the same error again
when i upgrade to newer postgres with postgis 3.x, right? What can I do in
this case?
On Mon, 27 Mar 2023, 23:53 Regina Obe, <lr at pcorp.us> wrote:
> Did you run
> SELECT postgis_extensions_upgrade();
> Twice on your 3.0?
> You should actually do the same on your 2.5 as well, as they are both at
> unstable states. The PostGIS 3.0 more so is unstable, cause it looks to
> have a mix of using the 2.5 and 3.0 libraries.
> I don’t think the 2.5 even supported Proj 8.2 or at least not a
> combination we’ve tested.
> Probably the issue is with difference in Proj 7.2 vs Proj 8.2.1
> Do you have these running on the same server or different servers?
> I think the proj.db files changed between 7.2 and 8.2 and so if the 8.2 is
> using a proj.db from 7.2 that could be a mess.
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> Behalf Of *pham lan
> *Sent:* Monday, March 27, 2023 4:59 PM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* Re: [postgis-users] ERROR: transform: Point outside of
> Sorry, my bad. I just realized that the information about the postgis
> version I gave you was wrong. So the original one is 2.5 and the backup one
> is 3.0. Can it be that the st_transform function caused the problem in this
> case for different postgis functions?
> So the output of select postgis_full_version() are following:
> #This is the output from the original database
> geodm=# SELECT postgis_full_version();
> POSTGIS="2.5.5" [EXTENSION] PGSQL="100" GEOS="3.9.2-CAPI-1.14.3"
> SFCGAL="1.3.1" PROJ="Rel. 7.2.1, January 1st, 2021" GDAL="GDAL 3.2.3,
> released 2021/04/27" LIBXML="2.9.1" LIBJSON="0.11" LIBPROT
> OBUF="1.0.2" (core procs from "2.5.2 r17328" need upgrade) TOPOLOGY
> (topology procs from "2.5.2 r17328" need upgrade) RASTER (raster procs from
> "2.5.2 r17328" need upgrade) (sfcgal procs from "2
> #This is output of the target database:
> geodm=# select postgis_full_version();
> POSTGIS="3.0.7 r487b488" [EXTENSION] PGSQL="100" GEOS="3.9.2-CAPI-1.14.3"
> SFCGAL="1.4.1" PROJ="8.2.1" GDAL="GDAL 3.2.3, released 2021/04/27"
> LIBXML="2.9.7" LIBJSON="0.13.1" LIBPROTOBUF="1.3.0"
> (core procs from "2.5.2 r17328" need upgrade) TOPOLOGY (topology procs
> from "2.5.2 r17328" need upgrade) RASTER (raster lib from "2.5.5 r0" need
> upgrade) (raster procs from "2.5.2 r17328" need u
> pgrade) (sfcgal procs from "2.5.2 r17328" need upgrade)
> On Mon, Mar 27, 2023 at 10:41 PM pham lan <phamlankt at gmail.com> wrote:
> you are right, if i dropped the aforementioned index, analyze works
> without issue. As long as I tried to create the index again, it does not
> let me creating the index but throw the same error.
> But I wonder why it is working in the original database. What happened
> during the backup/restore that changed this?
> Btw, I see some small difference in the output of the original database.
> May be it sounds something to you?
> (1 row)
> On Mon, Mar 27, 2023 at 10:21 PM Regina Obe <lr at pcorp.us> wrote:
> Could be your ST_Transform index triggering the issue and you have at
> least one geometry out of bounds in there.
> I’d try dropping your geobordervtc_geom_25832_idx and then rerunning
> analyze on the table.
> If that does fix it then try to gigure out which geometry is at fault.
> The 25632 is only good for utm zone 32N
> https://epsg.io/25832
> So I suspect you have a geometry way off from there causing the issue.
> Or it could be missing grid datum shift files at fault too.
> You can update your grid files by running at your command line:
> projsync --all
> As detailed here - https://proj.org/apps/projsync.html#index-0
> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On
> Behalf Of pham lan
> Sent: Monday, March 27, 2023 4:02 PM
> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> Subject: Re: [postgis-users] ERROR: transform: Point outside of projection
> domain (2050)
> Hi Regina,
> Here are more information:
> PROJ="Rel. 7.2.1, January 1st, 2021" GDAL="GDAL 3.2.3, released 2021/04/27"
> TOPOLOGY RASTER
> (1 row)
> On Mon, Mar 27, 2023 at 9:43 PM Regina Obe <lr at pcorp.us> wrote:
> What’s the structure of the table in question?
> \d+ name_of_table
> Should give needed details.
> Also output of
> Behalf Of pham lan
> Sent: Monday, March 27, 2023 3:27 PM
> Subject: [postgis-users] ERROR: transform: Point outside of projection
> domain (2050)
> Hi everyone,
> I need your help to figure this out. I have a DB in postgresql 10 with
> postgis 2.5. I know postgresql 10 is not supported anymore and we have plan
> to upgrade it soon but it is a different story.
> The thing is, I want to make a copy of this DB, so I tried a pg_basebackup
> to another postgres10+postgis 2.5 VM. After that, a vacuum went well but
> the analyzer throws an error on 1 specific table:
> i tried also pg_dump/pg_restore but get the same error. Does anyone know
> what is the problem?
> Thanks for your help!
> Regards,
> Lan
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230328/9159565f/attachment.htm>
