[postgis-users] ERROR: transform: Point outside of projection domain (2050)
Regina Obe
lr at pcorp.us
Mon Mar 27 14:52:47 PDT 2023
Did you run
SELECT postgis_extensions_upgrade();
Twice on your 3.0?
You should actually do the same on your 2.5 as well, as they are both at unstable states. The PostGIS 3.0 more so is unstable, cause it looks to have a mix of using the 2.5 and 3.0 libraries.
I don’t think the 2.5 even supported Proj 8.2 or at least not a combination we’ve tested.
Probably the issue is with difference in Proj 7.2 vs Proj 8.2.1
Do you have these running on the same server or different servers?
I think the proj.db files changed between 7.2 and 8.2 and so if the 8.2 is using a proj.db from 7.2 that could be a mess.
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of pham lan
Sent: Monday, March 27, 2023 4:59 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] ERROR: transform: Point outside of projection domain (2050)
Sorry, my bad. I just realized that the information about the postgis version I gave you was wrong. So the original one is 2.5 and the backup one is 3.0. Can it be that the st_transform function caused the problem in this case for different postgis functions?
So the output of select postgis_full_version() are following:
#This is the output from the original database
geodm=# SELECT postgis_full_version();
POSTGIS="2.5.5" [EXTENSION] PGSQL="100" GEOS="3.9.2-CAPI-1.14.3" SFCGAL="1.3.1" PROJ="Rel. 7.2.1, January 1st, 2021" GDAL="GDAL 3.2.3, released 2021/04/27" LIBXML="2.9.1" LIBJSON="0.11" LIBPROT
OBUF="1.0.2" (core procs from "2.5.2 r17328" need upgrade) TOPOLOGY (topology procs from "2.5.2 r17328" need upgrade) RASTER (raster procs from "2.5.2 r17328" need upgrade) (sfcgal procs from "2
#This is output of the target database:
geodm=# select postgis_full_version();
POSTGIS="3.0.7 r487b488" [EXTENSION] PGSQL="100" GEOS="3.9.2-CAPI-1.14.3" SFCGAL="1.4.1" PROJ="8.2.1" GDAL="GDAL 3.2.3, released 2021/04/27" LIBXML="2.9.7" LIBJSON="0.13.1" LIBPROTOBUF="1.3.0"
(core procs from "2.5.2 r17328" need upgrade) TOPOLOGY (topology procs from "2.5.2 r17328" need upgrade) RASTER (raster lib from "2.5.5 r0" need upgrade) (raster procs from "2.5.2 r17328" need u
pgrade) (sfcgal procs from "2.5.2 r17328" need upgrade)
On Mon, Mar 27, 2023 at 10:41 PM pham lan <phamlankt at gmail.com <mailto:phamlankt at gmail.com> > wrote:
you are right, if i dropped the aforementioned index, analyze works without issue. As long as I tried to create the index again, it does not let me creating the index but throw the same error.
But I wonder why it is working in the original database. What happened during the backup/restore that changed this?
Btw, I see some small difference in the output of the original database. May be it sounds something to you?
(1 row)
On Mon, Mar 27, 2023 at 10:21 PM Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
Could be your ST_Transform index triggering the issue and you have at least one geometry out of bounds in there.
I’d try dropping your geobordervtc_geom_25832_idx and then rerunning analyze on the table.
If that does fix it then try to gigure out which geometry is at fault.
The 25632 is only good for utm zone 32N
https://epsg.io/25832
So I suspect you have a geometry way off from there causing the issue.
Or it could be missing grid datum shift files at fault too.
You can update your grid files by running at your command line:
projsync --all
As detailed here - https://proj.org/apps/projsync.html#index-0
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org <mailto:postgis-users-bounces at lists.osgeo.org> ] On Behalf Of pham lan
Sent: Monday, March 27, 2023 4:02 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org> >
Hi Regina,
Here are more information:
POSTGIS="2.5.5" [EXTENSION] PGSQL="100" GEOS="3.9.2-CAPI-1.14.3" PROJ="Rel. 7.2.1, January 1st, 2021" GDAL="GDAL 3.2.3, released 2021/04/27" LIBXML="2.9.7" LIBJSON="0.13.1" LIBPROTOBUF="1.3.0"
TOPOLOGY RASTER
(1 row)
On Mon, Mar 27, 2023 at 9:43 PM Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
What’s the structure of the table in question?
\d+ name_of_table
Should give needed details.
Also output of
Sent: Monday, March 27, 2023 3:27 PM
Subject: [postgis-users] ERROR: transform: Point outside of projection domain (2050)
Hi everyone,
I need your help to figure this out. I have a DB in postgresql 10 with postgis 2.5. I know postgresql 10 is not supported anymore and we have plan to upgrade it soon but it is a different story.
The thing is, I want to make a copy of this DB, so I tried a pg_basebackup to another postgres10+postgis 2.5 VM. After that, a vacuum went well but the analyzer throws an error on 1 specific table:
i tried also pg_dump/pg_restore but get the same error. Does anyone know what is the problem?
Thanks for your help!
Regards,
Lan
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230327/163295e1/attachment.htm>
