[postgis-users] GML ver 3 id duplicated error
Michal Seidl
michal.seidl at gmail.com
Tue May 16 08:52:13 PDT 2023
Hello,
we use POSTGIS="3.3.1 3786b21" and have problem with validation of GML
geometry. The validator complains about duplicated "id" values in
generated XML in MultiSuface and Polygon.
<gml:MultiSurface srsName="EPSG:4326" gml:id="1">
<gml:surfaceMember>
<gml:Polygon gml:id="1">
<gml:exterior>
<gml:LinearRing>
<gml:posList srsDimension="2">0 0 0 1 1 1 1 0 0
0</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</gml:surfaceMember>
</gml:MultiSurface>
We have not found definition for GML ver 3.1.1 but for 3.2.1 by this
link
https://docs.geoserver.org/2.23.x/en/user/data/app-schema/supported-gml-versions.html
says:
If a multigeometry (such as a MultiPoint or MultiSurface) is assigned a
gml:id of (for example) parentid, to permit GML 3.2.1 schema-validity,
each geometry that the multigeometry contains will be automatically
assigned a gml:id of the form parentid.1, parentid.2, … in order.
Is it Postgis bug or difference between GML ver 3.1.1 and 3.2.1?
Thanks for help Michal S.
