need help
Bekir Niyaz
bagafoot at hotmail.com
Wed Apr 3 01:52:02 PDT 2024
Hello again I updated postgis from 3.0 to 3.3 but didn't execute "alter extension postgis UPDATE;" and restart db. The query was working well but after update it starts throwing errors below.
ERROR: type "geometry" does not exist at character 98
QUERY: SELECT ST_FlipCoordinates(st_setsrid(st_geogfromtext(replace(new.tesiskoordinat,',','.')),4326)::geometry)
it is a simple insert into sql, it throws only when inserted via hibernate,
postgis installed in public schema and
user has search_path= public, another_schema
table has select priviliges on public.spatial_ref_sys
when I check installed extention with \dx the output
postgis | 3.0.4 | public | PostGIS geometry, geography, and raster spatial types and functions
but when run select Postgis_Version();
3.3 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240403/975140fc/attachment.htm>
